mreurostar
- Joined
- May 18, 2013
- Messages
- 5
- Points
- 3
I have a2019 ducato which I have changed the cam belt and water pump. All went well u till I rotated the engine several times and noticed the belt was slipping towards the outside edge of the pulleys and also continued to slip over the edge. I then tried removing the belt and water pump and reinstalled them. After re over tensioning and rotating and resetting the tension, it seemed better. I reassembled the cover and auxiliary pulley and alternator belt and ran the engine. All OK for 10 mins or so then I could hear the cam belt rubbing on the cover. Does anyone know if there is a pulley alignment proceedure or suggestion to stop the belt creeping off the pulleys.
- Model
- Fiat ducato 2.3 multijet
- Year
- 2019
- Mileage
- 28000
