Technical seat belt tensor
markab 27
elgin
hallo my yellow warning seatbelt in on it was happend when battery was empty and jumpstart by A.A then notice .I find someone that put a computer and diagnose fault b101c , Driver seatbelt so whe check the seatbelt it says on line u can test it by measure between 2 3 ohm .The driver seat tensor measure 2.1 and passenger measure 1.9ohm. Cleaned all contacts do have buy a other seatbelt tensor pricey or can i but a second hand one .I looked one line its fiat ducato 2013 diesel do i need but same or can i buty one that looks similar i not can see the one whit serial number as mine Abit confused by this thanks in advance hans
When I took my double passenger seat out and replaced it with a single seat, I put a 2.2 ohm resistor in place of the third seatbelt pre-tensioner, which fools the computer into thinking the seat belt pre tensioner is still there so the warning light goes off. Could you try a resistor in place of the seat belt pre-tensioner and see if the light goes out (you have to switch the ignition off and on again)
