Our (2010 1.2 Dynamic Eco) Panda has an oil leak which shows up as a burnt oil smell whenever a drip lands on the exhaust. Both the Y-shaped hose from the cam cover breather to the air box and the sealing ring between the airbox and throttle body had clearly been leaking oil. (The hose was split at the engine end, the ring was loose fitting, maybe swollen and damaged by oil).
Very easy to find replacement parts except both the parts I ordered turn out to be a really bad fit. So I'd really value some advice on how to identify better ones. The hose, for example, clearly looks like the proper part but the size is just wrong - the middle part of the s-shape is about 25mm too long so the two ends don't line up with the hose barbs and the bore size at the engine end is much too big. Being silicone it's squishy enough to just about clamp down on the hose barb but I doubt it'll seal properly. I can't tell if it's actually meant for a different engine or if it's just a really badly made copy.
The other question that's bothering me is why there's quite so much oil in the hose at all. I'd expect some oil mist coming out of the breather but this seems excessive. Is there some kind of baffle or series of chambers inside the cam cover that's meant to trap oil mist before gases leaves the breather? (There is in other engines like the Mazda BP I'm more familiar with.) I could take the cam cover off to check for myself but now I'm paranoid the cam cover gasket I bought will turn out to be a bad fit too. The cam cover thankfully seems not to be leaking - I checked around it and it seems bone dry.
Any advice gratefully received.
