Technical 169 4x4 oil leak
PandaQ
Hi guys,
Does anyone know where to look (on the forum) for major oil leak at the rear main crank seal oil leak on the 4x4 trekking,
Or if someone don’t mind repeating info
I need to pull gearbox to replace rear main crank seal and sommer same time do clutch as I have a MAJOR oil leak, also tried to see if someone else had the same issue of finding oil leaks
What I’ve done so far
Oil cap( rubber one)
Tappid cover gasket
Seal behind the coil packs / brackets
Seal at oil pump side
Sump siliconed
So all the easy to reach ones.
Regards
Des
Model
169
Year
2006
Mileage
169000
Have you checked the gearbox oil
It very common for the input shaft to leak
There's an inspection hole at the top of the bell housing
Both main crank and input are fairly easy, only know of one diesel with a major leak from the crank bearing
Both require the gearbox off though
Thanks,I will asa it stops raining,
I use 500ml a week and there’s a puddle each time I stop somewhere.
Des
Des
Engine oil should be fairly obvious if it dripping on the drive
Sump
Valve cover are the normal places
But really it's a matter of getting some cleaner and seeing where it first reappears
Still check the gearbox if it's low it causes more damage
I have a leak developing on the sump (few thousand km after oil pick-up replacement). Mechanic says it is not the oil sump silicone that is leaking but rather the crankshaft seal on the gearbox side (picture attached).
I was wondering if there is way to make sure it's the crank seal and not the sump without removing the gearbox? Maybe removing the bellhousing cover on the bottom and look with a mirror ?
The plate does come off, but it's easier to use the inspection hole
Endoscope would help
But if you touch the inside with you fingers and is dry it's unlikely to the input or crank seals
Looks like it's leaking high up to me
