I think all of us who've worked on cars for our living have come across this sort of situation Mike. We always issued a written confirmation of work recommended and got the customer to sign it, if possible, retaining a carbon copy for our records. You really need to do this for your own protection.We are all on the same page Andy, any rust on the pad contact area the rust will always win, gradually expanding to the point the pads have no shiny contact area to even try to function on, long before that time, the Mot tester or service mechanic should have picked it up.
It is amazing to see the poorly functioning brakes on some cars. Over 30 years ago when my two youngest (twin girls) were being born my wife talking to the lady in the next bed to hers mentioned I was a motor engineer and arranged for her father to drop her Austin Maxi car to me to check the brakes as they were pulling to one side. Once the wheel was off I couldn't believe what she had been driving on, the brake disc had broken away from the driving flange completely, so the pads could grip the disc tight but not affect stopping one iota, consequently the car pulled violently to one side on braking. I showed this to her father/grandfather of new baby shortly to be driven in the car and he refused to have the work done, even though I was so concerned I offered to fit the parts free, just the trade price of the materials. He then took the car away, I issued him my normal invoice stating exactly what was wrong with the car and how dangerous it was, with no charge for my time , purely for my records if there was a subsequent accident and it was suggested it had been to me for repair. I also got my wife to tell the new mother how dangerous her car was!!!![]()
This is the difference between preventative and reactive maintenance.I remember Mrs J's Dad saying "if Jock say's there's something needing done on the car you can guarantee you can go on driving it for another 6 months before it's going to let you down" - He was an accountant and hardly knew how to even check his oil and water levels.
I remember disc resurfacing machines were all the rage at one time. a bit like on car wheel balancing. We never bought into resurfacing discs prefering to just fit new when needed. However, a "clever" salesman managed to get the boss to buy an on car balancer on the grounds that it did a more accurate job because, by spinning up the wheel and hub assembly together it achieved a "better" balance. We found that was very occasionally true but it would be defeated completely by even the smallest amount of play in either the wheel bearing or suspension. and it took considerably longer to set up and use than just taking the wheel off and balancing it on a conventional floor mounted machine - Most of the time you're needing to balance a wheel after fitting a new tyre so the wheel is going to be off the car anyway. The biggest problem with it was that it only really worked well on rear wheel drive vehicles as the drive train caused the wheel to slow down too quickly on FWD vehicles - Of course you could spin it up using the car's engine, but we found that didn't work very well (and now a days would be impossible with ABS). Anyway, with FWD becoming the norm, it wasn't long before this expensive piece of equipment went to "rest" at the back of the shop and gather dust.New brake discs cost £60 something, less than the £75 Arnold Clark charged to resurface the discs at the last main service I let them do.
Absolutely pointless on a solid disc that costs £15 and is made out if steel forged from the cheapest chineesium.I agree Jock re disc resurfacing, not a fan!
I recall using the Repco on car wheel balancer at college, the only time I had use for it was after catching some rocks in a lane as a teenager and damaging both wheels on one side of a 1950s Wolsely 1500, after beating the rims straight I managed to balance them successfully , but it involved weights nearly a third of the way around the 14inch rim, it was over fifty years ago.![]()
Agreed.Absolutely pointless on a solid disc that costs £15 and is made out if steel forged from the cheapest chineesium.
but you have an expensive floating disc set up on say a Porsche 911, where they are made from the highest grade materials and designed to be resurfaced with exacting tolerances of how much can be taken off.
and maybe one disc is £300 - 500.
Then there is a strong case for paying £75 for someone to skim it, and I wouldn't have any problem with that.
Pads can easily be reflatted by gently rubbing them on a sheet of emery paper taking care to ensure they are evenly reduced and flat. Can be done in just a few minutes. Makes it possible to get some wear out of them. Has the benefit of removing glaze at teh same time.When the discs rust like that, there is usually a corresponding chunk missing from the pads, so even if you remove the rust from the surface of the disc you still need to replace the pads.
Discs and pads wear together the rust tends to be harder for the pad to remove and wear away and the rust then gouges a chunk out of the pads.
You can resurface discs as long as they stay in the thickness limits of the disc (usually written somewhere is a minimum thickness) but very little point in doing this on cheap cars with cheap discs. far cheaper and easier to replace them, but resurfacing is much more common on expensive sports cars and super cars that use steel brake discs.
Used to have to deglaze squealing pads when they first did away with asbestos and material was too hard in many cases.Pads can easily be reflatted by gently rubbing them on a sheet of emery paper taking care to ensure they are evenly reduced and flat. Can be done in just a few minutes. Makes it possible to get some wear out of them. Has the benefit of removing glaze at teh same time.
I'd maybe do that to remove a bit of glazing but if they're scored it doesn't have to be by much before you need to remove a lot of material, and when I say a lot, 2 mm off a pad can equal many thousands of miles of driving for me as I am so light on brakes.Pads can easily be reflatted by gently rubbing them on a sheet of emery paper taking care to ensure they are evenly reduced and flat. Can be done in just a few minutes. Makes it possible to get some wear out of them. Has the benefit of removing glaze at teh same time.
As an apprentice in late 1960s it was common practice to blow out the brake drums with high pressure airline, the whole workshop would be full of it.Also I don't really want to breath brake dust even if it hasn't got asbestos in any more, the fine particles are probably not very good for my lungs (says the ex 20 a day smoker)
To be fair given pollution in the 60s with factories, cars and trucks with no anti pollution measures, everyone smoking. Everything being made of asbestos. Houses being heated with open fires...... that brake dust was probably the least of your worries, its amazing that more people don't have severe lung conditions now.As an apprentice in late 1960s it was common practice to blow out the brake drums with high pressure airline, the whole workshop would be full of it.![]()
I well remember the metalic taste at the back of your throat and, when you blew your nose the result looked like black paint! Never understood why we haven't all died of emphysema or lung cancer?As an apprentice in late 1960s it was common practice to blow out the brake drums with high pressure airline, the whole workshop would be full of it.![]()
I think nearly all the rust was on none braking areas hence no differenceThe new discs have made zero difference to braking performance. How odd.
