D4nny8oy
Established member
Sounds like a better idea, I find main dealer pricing on rather the steep side!![]()
And a case for the defence, m'lud:
Had a customer in with their cooling fan running constantly. Turned out a well-known Clutch fitting specialist had just recently replaced the cooling fan due to it seizing.
Upon investigation, Examiner flagged-up coolant temp sensor errors. Checking the connection revealed mangled terminals where some idiot with a cheap multimeter had stuffed the probes-in in a misguided attempt to test the fan after fitting, I presume.
So in an attempt to save a few quid getting something as simple as a cooling fan diagnosed and fitted (rather than go to a Main Dealer and their experience), it ended-up costing twice that in labour to remove and repair the terminals.
Now, this local garage may be more intelligent, and may be able to read the errors, but only the Fiat garage will have the part to repair it (if needed) and will need to confirm the fault with Examiner, as well as deleting it afterwards.
Now stop asking what the modified loom is for or you'll get the thread locked- we can't let that info out or else you lot will start chopping into the loom yourself's!
