farmer.palmer
So the clutch in my 2012 twinair got a bit sticky, and reading around the subject it appears as though both master and slave cylinders give problems so I thought I'd replace them both at the same time.
Ordered the bit both turned up as the correct parts, actually fitting them both took less than 1 hour. I then tried to bleed the system - nightmare.
I have a pressure bleeder which I run at very low pressure, around 5psi. When I opened the bleed valve on the slave cylinder the liquid seemed to pour out from around the base of the plastic housing rather than out of the bleed nipple and into my carefully arranged pipe. No problem, I'll vacuum the fluid thrrough, same issue I can hear it pulling in air around the base of the bleed nipple housing. I then condemed the new slave cylinder as faulty and refitted the old one, which did exactly the same thing.
Anybody else experienced this? It seems as though the little hex screw, when opened fractionally allows air or liquid to flow out around the where the plastic housing meets the body of the cylinder.
