that manual confirms that auto is the 2 stage mode, allday is the one stage, on is constant and off is off. i would carefully follow the programming procedure described in the manual to ensure you have set your program correctly for the times you want it to come on. its a complicated programming procedure.
if your boiler thermostat is set on low in winter then the boiler may never stop boiling, but only during the times it should be on as dictated by the programer, so your problem must be with the programmer, either how you programmed it or it is faulty.
