Technical Battery replacement
Dog78
Winchester
Hi, which battery would people recommend for my Fiat 500L 2014
1.6 Diesel?
I don't know if it has the original battery, it had an extensive history and receipts for everything but nothing for a battery.
If it is the original it has done exceptionally well, I doubt it but who knows.
The stop start does not work but it doesn't say it is unavailable.
I have been looking at a Varta, would anyone know if this one is the one that fits
Or I can get the original Magneti Marelli one.
If anyone knows the correct dimensions of the battery it would help a lot too.
The only dimensions i can find that say is correct 175mm W, height 190mm H and height 278mm L
All help greatly appreciated. Many thanks 🤝👍
Hi, i bought a new battery from Tanya batteries, an EFB, although they said an AGM would be fine under the bonnet.
Varta did only recommend the EFB so I went with that.
Can you change the battery without losing any memory?
Or do you have to take special precautions. I have read as many posts but they were for later or different cars, mine is 2014 1.6 diesel.
All help much appreciated, thanks 👍
Hi again 🙂
It WILL zero the clock, and trip distances,so MPG figures etc
Radio stations MIGHT be wiped
Radio Code should be fine,
As the Body Computer should store it's info 😉
If you are concerned you could always try a supply to the 12volt socket near the gear lever..
I did that on my old 1999 estatecar
Haven't bothered with "modern". Kit
Will do, the stop start has never worked, but it never says it is unavailable or has a fault, although I don't use it as for the driving i do.
So it will be interesting to see if it works with a new battery.
The present battery starts the car but labours if left for a few days.
Mot and service next month.
Hopefully i can enjoy the car then with no worry.
Help always appreciated, thanks 👌👍
Hi varesecrazy,
You was right the millage and other things like the radio stations, date and time.
I managed to set the time, radio.But the mileage readings in the dash are all over the place and it has a square on the last digit.
Will this all settle down and go to as it was before?
Any advice would be much appreciated. Many thanks 🤝👍
