Hi guys, what a PITA, according to MOT guy you’re supposed to replace the entire arm as the ball joint assembly is all one fixed unit. Sod that. Has anyone used a split gaiter as below please or can advise?
As above. Only right answer is to replace the arm. As said above, you cannot clean out the grit that is already in there, which will have already caused some wear to the ball and socket. That wear will accelerate, even with new grease and a new gaiter. Soon you will need a new arm due to the ball joint wear, as well as a new tyre due to the uneven wear caused by the play in the ball joint. Cheaper overall to replace the arm complete. That also gets you new inner bushes. The inner rear bush is the one that normally fails first, and generally has a lifespan of around 5 years/40k miles, although some last longer, or fail sooner.Only the MOT tester can advise you as to whether they'd accept such a repair.
Personally I'd just fix this properly and replace the suspension arm, they're not expensive. Chances are that water & grit have already got in, and lubricant has got out, through the failed seal. There's no way you can clean this or regrease it properly, so this kind of repair will likely fail outright in a short while. And sticking a split gaiter together is a nightmare; adhesives & grease just aren't compatible.
I'd agree the job is a PITA on the 500, since the bumper and lower crossmember have to come off to gain access. But do yourself a long term favour and get the job done right first time.
At 70k+ miles, chances are the other side will fail next year, either for the same fault, or for worn bushes as suggested in the previous post.Then comes another kicker, best practice is to replace both together. But once the bumper is off, doing the second one takes only a little longer.
It was fiddly and brain taxing but with patience possible and worked fine - more importantly MOT man was perfectly happy.
I'm not saying it's the right way or the best way (absolutely not) but when you're in a sticky situation and need a quick cheap fix to get you out of trouble, does it work? Yes.
Really glad my wife has normal arms...Replaced my wife's control arms on her 500 last year, they are tight, be prepared for an arm wrestle.
Ill bet my life they are still CONTROL arms though.Really glad my wife has normal arms...![]()
