This isn't to do with Euro 6... it's "the next EU thing"; which is a switch to measuring how much emissions are produced by a car-maker based on the size of the engines it makes and how many units it sells.
It's a complicated formula but basically Fiat (making predominantly smaller engines) has a very tight target to meet (91.1 g/km) - the tightest target of any manufacturer, somehow - which compares to 120 g/km its range produced in 2016.
Elsewhere, VW has to hit 96g/km.. while Merc' and BMW have a relatively comfortable 100 g/km.... Who said "EU rules always/again favour the Germans"? #cheatingpays
It's also worse than that (for everyone). Before the VW dieselgate the "test" for consumption was called New European Driving Cycle (NEDC). The new test is called Worldwide Harmonised Light Vehicle Test Procedure (WLTP) and it's a bit tougher (probably the VW sooftware gets disconnected..
) For comparison, a VW Up! GTI was tested under both tests and it performed 16% worse under WLTP.
The biggest drain against the target is big engines and SuV's.... so in this context, you can maybe see the impact on 500X which used to combine the largest engines Fiat makes into the least fuel efficient body style.
I can't see how the new rules is not another German con-job somehow... since it looks like if you happen to make big, dirty, polluting engines with cheat software you get a higher CO2 target.. and if you are a fairly innocuous manufacturer in "Southern Europe" you get shafted... Sounds like normal EU (why not let's get the f*** out of it) ... but what do I know?
More from Autocar:
https://www.autocar.co.uk/car-news/industry/analysis-how-will-car-makers-meet-new-co2-laws
Ralf S.
More from Autocar:
Ralf S.
