Hi All,
My Fiat 500L has a 126A1 engine and uses the 28 Weber carb. I have cleaned it out completely along with the fuel tank and the fuel sender. I have a filter between the main fuel line and the fuel pump. The engine idles just fine, and I get a steady flow of fuel in the filter (1/2 way full) at idle.
I'm able to go from idle to 1st gear and then to 2nd gear and then to 3rd, consistently, without any issues. Everything operates as expected from 1st to 2nd to 3rd.
However, after I change into the 3rd gear, sometimes I'm able to maintain a steady speed (not accelerate any further but keep a steady speed) at 3rd but I don't have the power/RPMs necessary to accelerate enough to reach 4th. When I do have a steady speed at 3rd, I once changed into the 4th gear, and it shifted just fine but without additional power or speed, so I eventually went back to 3rd. I'm able to shift into all 4 gears.
At other times, when I accelerate and change into the 3rd gear the car slows/reduces power. It feels sluggish as if it was doing better in 2nd. When this happens, even if I push the gas pedal to the floor, nothing happens. In this scenario, I noticed the fuel filter was 1/3 full instead of 1/2 (at idle).
Do you think I'm having a fuel supply issue where not enough fuel is making it to the engine or do I have a gear problem? I'm thinking maybe the fuel pump is not able to keep up with the demand or maybe I need to adjust the float in the carb to allow for more fuel storage in there?
The car runs lean, no backfires, no black smoke. I would like to be able to hit 45/50 MPH if possible.
Thank you for taking the time to read all this. Any suggestions would be appreciated.
- Model
- 500L
- Year
- 1970
- Mileage
- 33000
