- Joined
- Sep 19, 2020
- Messages
- 69
- Points
- 97
Hi there, it has been very difficult to obtain a spare wheel for my 2011 Fiat Ducato (Dethleffs) - I cannot believe they stopped supplying them in later models! I finally got one rim with a 215/70 R15 C tyre - which I am told is not for motorhomes - the ones marked CP are.
My question is, would it be OK to use this C version as a spare tyre? I imagine it would be fine to use on the front wheels, but not so much on the back because the tyre walls are not so reinforced?
If I did use it on the rear axle for an emergency, then it would most likely have only 50-100 kms to travel before fixing a flat tyre. Do you think it would safely hold a 3.5 tonne vehicle with about an extra 300 kg = 3.8 tonnes?
I have an Alco chassis, so I do not know if that makes much difference as the shock absorbers seem to be set up differently.
