Hi Dave, do you think there would be any point putting 500 springs with extra mounts on a standard 169 axle? Presumably this could be done by just removing the lower shocker bolts and letting the axle swing down still attached to the car (which I'm thinking of doing anyway just to treat the spring pans).The car has now done at least 10,000 miles with its new axle.
The only (very slight) snag was it riding a little low at the back with 500 springs. As said earlier, the Panda road springs were MUCH too hard so were quickly swapped back.
I then had a brainwave and fitted the rubber cushions from the spring tops to the bottom as well. I had two sets after all.
Ride height with soft springs sorted. !!!
OK, we wouldn't get the extra axle width or ARB, but it sounds like the springs alone could offer an improvement in ride, with the rubber spring mounts also protecting the spring pans. Any thoughts, please?
