Car is all back together now apart from the new engine mount I'm waiting for with the linkage all working, I was very tired the previous evening so I went to bed after having a bath, had a good night sleep & sorted it within a few minutes the next morning
turned out I'd knocked the selector when I had the gearbox out of the car so put the selector back in the right position & all is working again with all 5 gears & reverse so happy days, I fitted the modified clutch cable yesterday as well although the cable itself is a better design as it's just a hole instead of the usual hook which normally breaks I'm not too convinced on the fixings which is a nut & bolt as
A - It's a nightmare to get in & access is even worse than the usual hook cable so imagine trying to fix it at the side of the road if it snaps
B - although the pedal is lovely & light as a new clutch has just been put in it feels slightly heavier with the modified cable than the normal type cable even with a brand new clutch
So my thinking is the nut & bolt arrangement might be a slight strain on the quadrant which I don't want so I did a bit of thinking with a cup of tea this morning which is usually dangerous
& I came up with an idea which would make it a lot easier & quicker to fix if it snaps & I think less strain than the nut & bolt arrangement so I measured the hole in the cable & the quadrant & then the length with the cable & quadrant side by side as if it was fitted to the car, went onto Amazon prime & picked up some clevis pins with R clips for delivery tomorrow, the theory is it would be easier to change if I had to as all I'd have to do pull the R clip out as I'd have it in a position which would be easy for me to pull out & the just push the pin out to release the cable & the clevis pin through the quadrant all greased up whilst also being allowed to move around freely whereas the nut & bolt doesn't would be a much less of a strain on the mechanism so should be better for it.
Also some goodies turned up today, a nice new Momo steering wheel boss with airbag resistor
from eBay & a new 13 inch steering wheel which is a Temu chinese special so I was a little suspicious as to what it would be like but was very cheap at only £43 so isn't real leather for that money
but overall it seems quite sturdy & good quality, just to get an appropriate Fiat horn button now
It also has quite a nice feel even though it's faux leather/vinyl as I've never been a fan of the rugby ball style steering wheel in the Seicento's which is why I'd like to change it, my old Cinquecento also had the same wheel & I remember swapping it with the steering wheel from my dad's MK1 Punto the day before he scrapped it as I was an 18 year old with no spare cash & it was a free upgrade at the time
