R Runt Member Joined Aug 15, 2024 Messages 12 Points 52 Location Minneapolis Aug 15, 2024 #1 No fuel from old mechanical fuel pump to carb. Thinking about just converting to electric pump. Worried about constant flow to carb
B bugsymike Patron member Joined Jul 2, 2022 Messages 7,172 Points 2,300 Location Torbay Aug 19, 2024 #21 Runt said: Used the filter and the 3/8 slides on easy but the 5/16 goes on hard. I also thought 3/8 Click to expand... Being Italian it may be metric 10mm? only guessing and roughly similar. Upvote 0 Downvote
3 348azeus Member Joined Mar 21, 2010 Messages 78 Points 78 Aug 21, 2024 #22 I have twin 40 idf’s and run around 3psi. You don’t need much more than that on carbs. I run the same on Dellortos on an Alfa and SU’s on an MG. Upvote 0 Downvote
