Technical 100hp radiator
London
Hi all,
First post so my bad if this is in the wrong place.. (please move if it has a better place)
Proud owner of an 07 panda 100hp However I happen to have found a leak, and I'm guessing a crack, in my radiator so therefore would like to replace it. can only find one available just seeing if anyone knows a better one to buy or any recommendations on what to do
Thank you, Rudy
Search for
Fiat 51764957
Seems to pull a few up new and secondhand
Be careful with autodoc not all there listings are correct, it's only money back if you go through their compatibility checker
Good spot, looks like it's fairly fresh leak still nice and pink not dark red
Can't recommend anyone online, I look online first, then phone round my local motor factors, usually when I say I already got a quote for xyz I can pick one up locally for very similar money
Hi all,
Thank you, Rudy
View attachment 461763View attachment 461765
Hi mate and welcome.
Unfortunately you can’t get direct replacements anymore so you have to get a 1.3 one and slightly mod it to fit.
I replaced my one last year I have the box in the garage I’ll give you the part number over the weekend!
Hi all,
Thank you, Rudy
Hi mate,
Find attached the part number for the rad, you have to modify the upper pipe connected and remove the lip and the pipe with just fit on with out the speed connector.
Hope that helps
