Davidbroooks
- Joined
- Dec 6, 2007
- Messages
- 5
- Points
- 1
My daughters 1.2 8V Punto (2000 X) broke down the other day. A quick check over revealed not much water in it and it looked like a classic overheat and blown head gasket. Turns out she hasn't checked the water for quite a while!
So I pulled the head off and uncovered a bit of a mess. Pistons 3 and 4 had bits missing off the crown, so it looked like a full or partial seizure. Got the sump off eventually (that gasket goo is pretty sticky) and got the pistons out. All but piston 1 has evidence of seizing, 3 and 4 being the worst.
Now I've done a quick tot up of replacement parts and gaskets (throw in a cambelt change while it's apart) and I won't have much change from £300, especially if the liners need a rebore and not just a quick hone.
I've seen a couple of 1.2 8V engines on ebay for around £300-£400 which is probably an easier option, but I'm confused about which one I should get.
From around 2001 it seems this engine has a cam sensor fitted which mine doesn't and talking to the dealers the two engines can't be swapped because the sensor is all wired into the loom.
Any ideas or advice?
