Technical '06 Panda crank sensor issue.....
Everything measured okay
You only needed to measure resistance between green cable and earth, battery disconnected
Green cable and power, battery disconnected
To finish the checks on this networks wiring
Great as far as wiring this network is fine
While the body computer is apart you might as well post some high resolution pictures and see if anything stands out
And that's the resistance between green and brown on the car
That's the 11 and 20 pins plug from the bottom and it doesn't add up that they go to 35 and 36 and just stop without any apparent connection from the other side or the same side.
I'm not sure if you're good at electronics as I'm lost now anyway lets start with:
red giving perfect continuity,
Blue OL
Yellow OL
White 904 nanofarade
Black 4.405 Mohm
Let's stop
Your mixing up B CAN networks with C CAN networks
The normal 60 ohms network everything measures just fine, eventually
120 ohms with one end disconnected, the extra 5 ohms is just resistance in the wire, everything tests as it should up to the BCM, this is where the network stops, it does not go to the OBD port at all, Fiat chooses to use the pins for a different network
I have no idea what we are measuring on the BCM the board is multi layered I don't know where all the pins go we are only going to end up with useless information
I would be nice to get a closeup photo of each side while it's now apart to see if anything jumps out, we really didn't need to take it apart, only needed the resistance between pins 11 and 12 of the BCM originally
Alright but i just wanted to mention that these pins that i mentioned on the obd port, i measured them on the bcm got 7 mega ohms then it went back to OL I'll send you a picture taken by my phone if it's not good I'll have to wait for my sister to come back with her iphone and then I'll sen you a better shot of it
There ya go
But if the BCM is fine we're going back to the car?
Be worth post a close up of the areas I circled in photos above, while it's apart
This is what I am looking at
If I zoomed in on similar component
From a board in front of me now
We can only work with the information given
Half half hour they're good if not I'll send a picture of where you asked me to focus on
Probably a shadow looks perfectly clean
