Technical '06 Panda crank sensor issue.....
Here's the test being preformed
Just a brief repeated taps as the fuel pump primes
Leave the brown and red, the other two wires
Yeah the radio is aftermarket, we disconnected it and nothing changed at all want me to pull it out?
Gonna try your test koalar but this is the video of the coil pack in action and no spark
  • VID_20240411_154250.mp4
    33.7 MB
Forgot to mention radio was pulled out and tried cranking I'm getting nothing still
So i tried about 6 times priming while very quickly tapping with the tester on the negative while back probing the coil managed to get one and only spark
Great
So we have one working coil
Can we get a spark out of the other
You have to be quick like brushing across a pin
I want to test the coil is able to produce a spark, there was a common problem with them on the Punto but we don't see any nowerdays
Tried about 10 times and tried on both plugs aswell couldn't get a spark gonna try swapping the coil plugs maybe it's line is deficient
I think i still have my old coil pack gonna try putting it back in see if the issue is fixed because i tried a couple times again and it didn't give a spark at all
Tried the old coil pack that was intermittently stopping when i got the car and still couldn't get a spark
Is it possible now that the ECU is faulty?
It's possible
The fact it worked, then didn't, then did for a short while makes it less likely than wiring
Dry joint inside would be one cause
Tried my coil pack, it's not a good test on these waste sparks coils
Still need to check the resistance of the CANBUS network
One more thing does the coil pack uses the engine to take the ground? Or is it simply supplied by both wires only?
Positive to the + terminal permanent while the engine is turning
Negative to the - terminal switched via the ECU
There's no other connections it's just a metal cage
You can see this with an ordinary test light, disconnect both coil leads and probe the signal side of one connector with the other end on battery positive, worth a quick check incase one coil is stopping the whole system
Like that you mean?
