Hi mate,
Fuel issue shouldn't trigger the crank sensor error. And the fact that your LP pump is priming rules out the fuel cut off switch.
Does your LP prime and then stop? or continue to run?
Also ive just read back through this thread to see if we are missing anything... you say the code was P0355... are you sure this is correct? and it wasnt P0335
Did you check the continuity of the wiring for the crank sensor?
Alan
Alan
