Styling show us your engine bay
That is indeed a very high-tech block of wood! Its been removed now as Ive reshaped the bracket to allow it to hold shorter battery.
Bracket has also been painted and a DIY oil catch tank installed, just havent got a descent picture of it due to it raining alot!
your engine bays look so good painted,have you just painted stuff with a brush or removed it ?
Mine or Brins?
Mine is just painted with a brush, a quick clean up and rub over with sanding block is all that I done. Then slap the paint on with a brush, just use some card around the edges so you dont get a load of runs...
The paint i used was normal Hammerite direct to rust.
