How to bleed the cooling system, including pics.,.,
this is the bleed screw on the radiator,
This is the one behind the airbox.
This is the fan switch
(daves wording)
(daves wording)
- Undo both screws
- Fill header tank right to the top
- Squeeze all the hoses
- Keep repeating this until a fair amount of coolant is coming out of both bleed screws
- Do up the back one
- Keep squeezing hoses so coolant keeps coming out of the radiator bleed screw until the coolant is at max
- Do up screw
- Replace radiator cap
- Run engine until fan comes on
- Let it cool for a couple of hours
- Finally, check the level and top up to max if needed.
