celshady
Hi all!
I'm the new owner of a 2007 1.2 dynamic. I have some 15x7 wheels lying around in the garage and would like to fit them to the Panda if possible. They are 4x100, so I'm aware I'll need wobble bolts.
They also need new tyres, as the ones they're fitted with are 205/50r15. According to the Oponeo calculator I will need 185/45r15, which according to yet another website, doesn't look like they're stretched.
I need to check the offset as I'm pretty sure it's around 40 - which according to the panda/46897-rim-sizes thread might be a problem.
Those in the know, will the offset cause an issue clearing the brakes/suspension? Or is it arch clearance? Or both?!
I've read a bit on similar forum posts (sorry no URLs as this is my first post), and I understand there'll be a performance decrease. I'm not too fussed about this as the Panda is just my commuter daily. It won't see full lock very often either - my commute is 95% motorway.
If they fit and if I run them, I'll probably want to drop the suspension a bit too. I have at least one knocking shock on the rear, so replacing at least a pair in the near future - could just as well do the lot. Would you recommend standard shocks with lowering springs, or cheap coilovers?
Hope you can shed some light for me! I'm not married to using the wheels, just want to know if I can
Tom
Tom
