That was a mammoth read and a rollercoaster ride.
It’s been a really wet couple of days this way so maybe your way too… problems not related to the daughter driving through big puddles?
Seems to me either the fuel rail pressure is going low (hp pump fault or too much leakoff at any point on the HP side) or an electrical problem.
I’d also swing towards checking the easier thing first - as the old rail engineer told you – oh sorry railway engineer – not fuel rail engineer :doh:
If you’ve already done it I must have missed it in this thread.
Electrical signal path from rail pressure sensor to ECU - did you check the wires between the fuel pressure sensor and the ECU for good electrical continuity?
Looking at the fuel rail in the
eper the sensor (3) in is at the other end on the fuel rail to the pressure regulator (2). There is only 1 perimeter a sensor on the fuel rail is monitoring…. Fuel pressure
I think the fuel regulator at the battery end also has an electrical connection (looking at pics I took from when I replaced by MJ fuel pump). Probably worth checking both electrical paths to the ECU. Have a low resistance. I’ve no idea which pin but the wire colour code may be constant if there are no fuses in the way. May be worth checking the rail it’s self has a good ground path back to the battery (if it’s grounded).
Ahhh I found a good pic of my rail and you can see the electrical connectors at each end... A = Rail Pressure sensor, B = electrical connector to rail pressure regulator, C = Fuel rail leakoff hose
Not sure what peramiter is being picked up from the connection to the regulator but I suspect it's not rail pressure.
If the signal path is good then check the pressure sensor is good (no idea how to check it) and then the pressure in the rail (no idea how to check that) but there is plenty on the Corsa side of things if googling P0090. It’s a generic code after all
Did you spray that Italian contact cleaner on the both fuel rail and ECU plugs? Think I had damp in there once.
Regarding the in filter fuel heater yes there is supposed to be one in the Panda’s UFI filter housing. I’ve been told where I work that it’s redundant in the UK as we have winter fuel… Our similar engines run fine without heating the fuel on arctic cold days. this is off highway tackle mind you
