Technical Wires harness cable rear trunk
Divo
Regarding GP T-jet 2009
I need to replace the wires that goes through the cable throughput the one aside the hinges of the reardoor. (see pic)
Ofcourse I simply can connect some new wires as repair but I like to know the function of all, just in case something is not working right.
Does anyone has an electrical scheme? I couldn't find. In mine I count 11 wires + wiper water line
Are there more functions involved than these 4?
- Rear-screen wiper
- Third brake-light
- Boot lock
- Rear window heating
Thanks, I already looked to possible info on sources like that but its total rubbish those schemes.
The info I'm looking for is not there, or I overlook something. . . .
I cant find a description what all the wires in the bundle are by color and function.
This is a Fiat style of providing diagrams/schematics. Yes, it is dumb.
They split almost everything by function (so I guess there's no "front right door diagram" for example - it's separated into: mirror, locking, windows, speakers and so on). Or there can be "full diagram" if the panel has separate, dedicated connector (plug/socket). If not, like boot/trunk door, it's shattered into multiple functions.
But you can still do "reverse engineering" using those bits of information. Track ("ping") wires to the pins in the Body Computer and fuse boxes etc.
Wiper: https://aftersales.fiat.com/elearnsections/main.aspx?nodeID=199008338&languageID=2&markID=1&modelID=199000000&valID=199000005&prodID=199000000&modelName=Fiat - 199 - Grande Punto&langDesc=English&sectionName=Impianto Elettrico&validityName=1.4 16v TJet&isExaminer=
Boot open: https://aftersales.fiat.com/elearnsections/main.aspx?nodeID=199008373&languageID=2&markID=1&modelID=199000000&valID=199000005&prodID=199000000&modelName=Fiat - 199 - Grande Punto&langDesc=English&sectionName=Impianto Elettrico&validityName=1.4 16v TJet&isExaminer=
Some functions like that have feedback (limit switches for example), so it's not actuator (motor) only. There will be more wires involved.
Then, add some doubled powers and/or multiple grounds to the mix. Therefore "4 functions" require way more wires than 4.
In the "boot opening" section, you can click on the actual part (N057) in the table below picture. Lock motor. It has a plug. There are colors coded (abbreviations) and cross-section (is it thick or thin wire).
https://aftersales.fiat.com/elearnsections/main.aspx?nodeID=199004354&languageID=2&modelID=199000000&valID=199000005&prodID=199000000&markID=1&isExaminer=&dhb=BOOT OPENING - WIRING DIAGRAM&modelName=Fiat - 199 - Grande Punto&langDesc=English&sectionName=Impianto Elettrico&validityName=1.4 16v TJet
Example Google search query: https://www.google.com/search?q=fiat+color+wires+abbreviation
Example result (may not fit Grande model):
full
Defrost: https://aftersales.fiat.com/elearnsections/main.aspx?nodeID=199018350&languageID=2&markID=1&modelID=199000000&valID=199000005&prodID=199000000&modelName=Fiat - 199 - Grande Punto&langDesc=English&sectionName=Impianto Elettrico&validityName=1.4 16v TJet
Third brake light: https://aftersales.fiat.com/elearnsections/main.aspx?nodeID=199008283&languageID=2&markID=1&modelID=199000000&valID=199000005&prodID=199000000&modelName=Fiat - 199 - Grande Punto&langDesc=English&sectionName=Impianto Elettrico&validityName=1.4 16v TJet
