Technical What cable for MES connect to engine?
zippeyrude
I bought a KKL Vag cable and the 4 coloured cables (yellow, green, red, yellow).
Ive been able to connect to the airbag ECU with the red cable and now i wanted to connevt to the engine.
MultiEcuScan doesnt seem to want to connect with the KKL and Yellow cable (CAN system). Is the correct setup or do i need an ELM327 cable?
(I tried to connect my cheap chinese ELM327 bluetooth, that connects to TorquePro bur not my laptop for some reason).
any ideas how to connect MES to the engine (its a 2005 4x4)
thanks!
What does the supported vehicle list say?
On my new car it would not connect to much..
The list said I needed an adaptor (not needed one for years..)
READ THE LIST 👍
Segment of list
Panda '03
1.1 8V
Magneti Marelli IAW 4AF/4EF/59F/5AF EOBD Injection |INFO|DTC|DTC EX|PRM|ACT|ADJ| KLELM
Magneti Marelli IAW 4AF/4EF/59F/5AF Injection (Outside EU) |INFO|DTC|DTC EX|PRM|ACT|ADJ| KLELM
Bosch ABS 8 |INFO|DTC|DTC EX|PRM|ACT|ADJ| KLELMA1P1
Bosch ABS 8 VDC |INFO|DTC|DTC EX|PRM|ACT|ADJ| KLELMA1P1
TRW Airbag 2 (Ep - PROXI) |INFO|DTC|DTC EX|PRM|ACT| ELM
TRW Airbag MY99 |INFO|DTC|PRM|ACT| KLA2P3
Delphi Electric Steering |INFO|DTC|PRM|ADJ| KLELMA1P9
Service Interval Reset (Base) |INFO|ADJ| ELM
Service Interval Reset (Comfort) |INFO|ADJ| ELM
Connect (NAV) Marelli |INFO|DTC|PRM|ACT|ADJ| ELM
Instrument Panel Marelli (Base) |INFO|DTC|PRM|ACT|ADJ| ELM
Fiat
Panda '03
1.2 8V
Magneti Marelli IAW 5NF EOBD Injection |INFO|DTC|PRM|ACT|ADJ| KLELM
Magneti Marelli IAW 5NF EOBD Injection (Outside EU) |INFO|DTC|PRM|ACT|ADJ| KLELM
Magneti Marelli IAW 5SF8 CF5/EOBD Injection (1.2 8V) |INFO|DTC|DTC EX|PRM|ACT|ADJ| KLELM
Magneti Marelli IAW 5SF8/SDU CF5/EOBD Injection (1.2 8V LPG, 1.4 8V LPG) |INFO|DTC|DTC EX|PRM|ACT|ADJ| KLELM
Marelli SELESPEED CFC228F Automatic Gearbox |INFO|DTC|DTC EX|PRM|ACT|ADJ| KLELM
Bosch ABS 8 ASR |INFO|DTC|DTC EX|PRM|ACT|ADJ| KLELMA1P1
Fiat
Panda '03
1.3 JTD/Multijet
Marelli 6F3 EOBD Diesel Injection (1.3) |INFO|DTC|DTC EX|PRM|ACT|ADJ| KLELM
Marelli 6JF EOBD Diesel Injection (1.3) |INFO|DTC|DTC EX|PRM|ACT|ADJ| KLELM
Marelli 8DF CF5/EOBD Diesel Injection (1.3) |INFO|DTC|DTC EX|PRM|ACT|ADJ| KLELM
Instrument Panel Marelli (Comfort)
To connect just to the ECU
No Adaptor Adaptor needed with either the elm327 or KKL
In device manager is there any yellow exclamation marks
You have to install drivers
Then adjust some settings
To get the KKL to work
The Bluetooth should just work, once paired
It can only pair to one device you might have to shut your phone off or disconnect it first if you have already connected to a phone, to work with a laptop as well
thanks!
You don't say if its Petrol or Diesel,
But it Should.. work with a bare ELM327 or VAGCOM KKL according to the lists
You can either :
select engine and ECU variant
Or
Scan for Devices..
I tend to SCAN.. as there are often a choice of ECU
Tell us how it goes 🙂
