Technical steering alignment 2007 1.3 d
have replaced tie rod ends and lower ball joints and want to do alignment .am i right in thinking it is toe in on front wheel drive ?..
My manual for some reason doesn't show a 1.3 Doblo. On the 1.9 Doblo I read this as parallel to 20 minutes toe out as max. tolerance, with ideal 10min. toe out when using a wheel alignment gauge.
This makes sense to me as generally front wheel drive vehicles pull the wheels in and rear wheel drive vehicles push them apart.
Perhaps another Forum member has exact data for your 1.3 :)
thankyou you are correct it is toe out i have set it too 2mm and will keep an eye on how goes from now . many thanks for your help
