Technical Seicento 1.1 Spi starting problem
Maxbreaksfiats
Beesel
Greetings,
I have a problem with my sei not starting. Last year around november the car overheated on the highway and shut off, turned out to be the head gasket failing quite dramatically, sucking all the coolant into the cylinder in a rapid fashion. My father in law picked me up, adamant that it just needed a push start, failing of course. Since then I've taken the whole thing apart, changing/checking everything.
I've replaced the spark plugs, spark plug leads, battery, water pump, belts, tensioner, and i've had the head revised. Should run now, I'd think. The car disagrees. It turns over, there's fuel and spark, but it doesn't start. Anything I'm missing? Here's a video:
