Parts book
Barchetta Parts book
No permission to download
Wiltshire
Wiltshire Chris submitted a new resource:
Parts book - Parts book
A PDF version of the parts diagrams from V84 of ePer Copyright(c) 2011, Fiat Automobiles. The PDF's are produced using code that is Copyright(c) 2021, Chris Reynolds.
The whole document can be downloaded as a single PDF or there is a ZIP file containing a PDF per section which might make printing a little easier.
The source code for the utility to create the PDF's is available under the MIT licence at https://github.com/OldBoyCoder/ePerPartsListGenerator
The code is a little...
Read more about this resource...
Wiltshire Chris updated Parts book with a new update entry:
New versions of parts book covering releases 20 and 84 of ePer
With thanks to @Davren I now have access to the database for release 20 of ePer.
I have re-written my code to produce the parts book so that it can work from both release 20 and 84 of ePer.
Which version should you use? Where Fiat has discontinued parts these may be missing from the later version but the later release will have more up to date part numbers so it can be worth checking both.
For each release I have uploaded three files:
  • a PDF that contains the...
Read the rest of this update entry...
