Panda Panda 100HP project (cooperman style!)
Right thought I would start a thread as there are a few mods happening to my panda and wanted somewhere to have them all in one place! I have owned my 100HP since 2010 and love it! She gets serviced at fiat evry year and had belts and water pump replaced last year. I wanted to start modding her but not go OTT as been there and done it before! Hopefully you guys like it!
So this is what I have done:
Day one cleaned!
BMC Panel filter replaced and clear indicator bulbs front and back fitted:
Before
After
Gear leaver blue detailing done with touch up pen:
Ultersport rear 80mm back box fitted, with multi hole exhuast rubber to space it away from the bumper:
Before
After
Home made induction mod give great induction noise over 3000rpm!:D here is the link to how I made it https://www.fiatforum.com/panda/319449-100hp-induction-mod-under-30-a.html:
Before
After
New tax disc holder fitted:
Before
After
Pressed metal plates (Yes I know the legal issues with these before everyone starts kicking off!:devil:) but wanted to have a clean look!
Front
Really happy with the way the car is coming on! The rear end is looking nice and fat, will be looking at getting a silver rear fog light bulb to balance up the lights and looking at spacers the same as Demi has to fill the arches a bit more. All 4 tyres will be getting replaced also for Toyo T1R's as got some cheap front tyres put at the mo and had enough of them!! Lesson learnt!
I'm sure I read somewhere that it's more involved than just changing the rear fog light bulb if you want to balance the look of the rear lights. The red part is actually a lense with a clear bulb behind it (I think). You'll need to buy a rear light cluster for a LHD car and then you can fit silver/red bulb.
Mike
Mike
Indeed it is, done it on our Panda so that we've 2 reverse bulbs. It's a replacement lense job (y)
Cheers for the heads up guys, I read it somewhere to! Thats what ebay italy is good for. think they are like 50 euros's a side, when I get the bulbs will take the cluster off and do abit of R&D! Will keep you posted!
Looking good! Can't wait to pick mine up.
Like the idea of the rear cluster. I changed my Puntomk2 ones for the Mk2b jot get the clear light parts. I'm debating using a flyeye type kit to just go dark on mine along with the headlamp
I have had a busy morning, I have done a update to my induction kit mod and have replaced the alloy pipe with a carbon one. Think it suites the engine bay a lot better and matches the other black pipes.
Before
After :D
Ok at this point I have to hold my hands up and confess it is still the alloy pipe just with 4D carbon wrap, only coat £6 for a big sheet and think it is bang on! here is the pipe:
Before
After
What was interesting while i had the alloy pipe removed when you look inside of it you can see marking from bits in the air flow so seems to be doing its job very well! :devil:
Like all things as I had a bit of carbon wrap left over thought i would give the interior wing mirror covers a go! I am just a bit impressed with the finish! Just not sure if its to much or just looks cool! :confused:
Before/after
Left
Right
Patten
does anyone know the correct part no. for a 100hp /lhd / passenger side / right hand rear tail light cluster ? thanks.
Mhmm, watching and drooling :D. Specially when they were at 99p ;)
btw, what happened to them Abarth seats I linked u with, how much did they go for in the end?
£300 in the end :(
Just have to keep watching
