Styling Instrument cluster
deafmazter
Will a 1.2 16v mk2a sporting instrument cluster work in a punto mk2a HGT?
Or wil de speedometer have a little deviation?
I need to know because of a project car, already thanks for helping me out:)
To my knowledge only difference if HGT going to 240 km/h (150 mph I suppose) whereas Sporting goes to 200 km/h (120 mph).
I noticed this when I was at a salvage yard and saw two instrument clusters in the foot area of an HGT. Connectors seemed to be the same.
So, my untested and unverified immediate response, would be that you can interchange them no problem.
I strongly assume the resistors in the HGT are just stronger so that any given signal just make the needle move fractionally less that it would on a Sporting speedo.
Should be ok.
I’m sure if you scout the forum you’ll find someone who’s made the swap before.
Thanks for the info, I got a whole panel for 10€.
When I’m back from vacation i will instal the panel and let u know of everything works.
What u said about the kmh is right, my hgt does not go faster than 210kmh so the needle is out of range by maximum speed ??
