500 Hi to all
500 Hi to all
godtfred1000
Norway
Hi my daughter have a 2013 500 twin air 0,9 that not start.
She was driving to gas station and fill fuel it was almost empty.
And it did not start after that. We have check plugs that have spark.
Try with start gas but no ignition. My friend check it with diagnostic tool and got
foult P0300 and P0302.
Welcome, Merry twixmas. 🍻🥃☕🍾
I don't think it was "almost empty", the codes you mention are missfires, and probably due to being 'empty'.
But IMO, would keep turning it over, it should start as soon as the fuel rail is full & pressurised. If it wasn't broke before it isn't broken now, least not by just running out of fuel. Get the fault codes deleted, and try starting again.
Let us know how you got on. 🎉
Hi is it the blue pipe that come from fuel pump, tank?
Hi🙂
Twinair is an unusual system
It uses oil pressure to control fuelling
Low Oil flow will stop injection of fuel
Has your family owned this car long, covered lots of kms..?
Is the air temperature COLD this week..?
An easy test.. 🤔
When spinning engine.. Does rev counter /tachometer needle climb or jump..?
You need to answer Varesecrazys questions, he has more experience with the 500....
Not got a Twinair near today,
But I think that is NOT fuel..
( But fuel vapour recovery)
Carefully watch the dashboard instrument lights when you try and start the engine
Do you hear the fuel pump under the back seat..?
Yes I can hear the pump, sounds like it work good
Hi some fault code from today
