HELP !.
Any Mechanic/Auto electric people out there ???
Had an intermittent problem with the Fist Ducato 2.8Jtd 2006 Motorhome on and off for a few years now.
Occasionally when I go over a bump it will cut out and engine lights come on, had it looked at a few times but no luck as it's not doing it when been looked at !!!
To cut a long story short we've narrowed it down to the main due/relay box (see photo) and assumed loose connections !!! .had them all checked and all seemed ok !
Happened again today so I immediately pulled over and removed the lid and started pushing on the connections !!! (Always.worked before) I noticed when doing it that (A) was making a Buzzing sound when I pushed and rocked it. ??? I just happened to be in the middle of nowhere but miraculously near a garage and got the relay changed !!!
All seemed ok.......
Got to the campsite and thought I'd just check again BUT NOW THE RED RELAY marked (B) is also buzzing when touched and THE IGNITION IS OFF ????
UPDATE !!! Got up at 05:00 to use loo, and noticed yellow warning light on Dash
And the relay was constantly buzzing had to puli in out ????
Any help appreciated as in the middle of nowhere
Water in diesel filter warning light | AMBER |
