So... Comfortmatic will go into 1st or reverse when the engine is not running, but when the engine is running I get the 'gear unavailable' message and some soothing beeping.
Due to error codes in the gearbox ECU, I suspect there is an issue with the CANBUS and am seeking some advice on where to start checking wires and cleaning contacts. Specifically: where is the gearbox module physically located? Is there a CANBUS amplifier or other control unit somewhere?
I have read many posts about earth strap and the wires behind the wiper motor and left side headlight. I did have the windscreen scuttle issue but used some tape and sikaflex to fix it, but I still get water ingress into the engine bay and have seen water on the loom behind the passenger side headlight...
Some history of the problem and troubleshooting:
This first happened a couple of months ago, and the garage said they cleared the codes and reset some gearbox parameters and all was well (until now...). It has happened again, so I thought I would have a go, rather than be recovered again...
So, I have bought an OBDLink interface and Multiecuscan. I can see what I need to do when in 'simulation' mode, but I cannot connect to the gearbox module... or any module at all. I can 'Scan DTC' and see error codes, which I have done. I have posted a question on the Multiecuscan forum, but I suspect my issue is actually Ducato-specific, to do with the wiring loom and electrical contacts...
Initially I saw U0001-88 error code, but after I cleared codes that one went away. After several rounds of clearing codes and trying to get it into gear, we are now settled on the following error codes presented by the gearbox control module:
Gearbox / TCM/NCA/NCR (Automatic Transmission)
Marelli SELESPEED CFC348 Automatic Gearbox
ISO Code: BC 07 A2 8A C4
Hardware number: CFC 348F.09 - Ver: 00
Software number: FGC11IOF - Ver: 0000
Errors found:
P0857-86 - VDC messages (from CAN) - Signal/message invalid
P0856-81 - VDC messages (from CAN) - Invalid serial data received
The key here I think are the CAN errors: the gearbox is expecting messages but not recieving them. I suspect a short or open circuit somewhere.
So I suspect this is why it won't go into gear when the engine is running, but will when it isn't (the garage confirmed that there is nothing mechnically wrong with the gearbox, and I can hear it happily selecting 1st and reverse when the engine is off). The above codes are to do with traction control, and I think it's a safety feature. After a while of trying to get it into gear I often get the 'hill assist unavailable, and 'ESP unavailable' error messages too...
Anyone seen this before? I saw a post on another forum but it was from years ago and sadly the OP did not post a resolution...
Errors found:
