General door seals
General door seals
tipo93
Hi all, can anyone recommend somewhere were i can get new door seals for a 1993 fiat tipo 5dr. have searched the internet & will keep searching but if anyone has any info then i thank you in advance
Hi
I can imagine there will be an element of improvisation required
You mean the 'soft rubber tube'
That clips around the pressed steel of the door aperture?
Other later FIAT ones might adapt easily
Do NOT use anything to a FORD pattern they dont last 3 years.. nevermind 30 :eek:
yes the rubber that goes around the opening, not the actual door itself
