Hello!
I am writing to you about problems that are quite common, but scattered in different topics and the final solutions are different.
I am the owner of Fiat Sedici 1.9 multijet 120hp 2006. 4x4. There are two problems with the car. The first is that it puts disel in the oil and the second is that in the morning in colder weather it start on hard, and a lot of white smoke comes out. The second problem is only in the morning with the first ignition, then no problem. Once started, there is no problem with the engine. After a lot of reading on my part on all sorts of forums, I came to the conclusion that the solution to both problems comes from a failure, which has two options for solving, but for volkswagen car.
1. O-rings on the nozzles
2. Tandem pump
I add that last night I parked the car on a slope. Buttocks higher than the front. This morning it lit for the first time and without smoke.
I made two more attempts to start the car after it was tilted first and it starts from the first time and two attempts to start from a horizontal position of the car and start from 3-4 times
My question is. What do you think is the problem with the listed symptoms of my Fiat Sedici.
Thank you in advance!
2. Tandem pump
