General Bosch Mono Jetronic
ndroz2003
Indonesia.
Dear All,
Could anybody tell me how this kind of Fuel Injection System works ? and how to tune for the best result ?. My Uno using this kind of Fuel Injection System, and I need some information for setting Idle and Idle Pre-Warming.
Many Thanks,
Hendro. N
AIUI...
This is a very basic system which is trying to mimic a twin choke carburettor.
The quantity of fuel injected is determined by the following:
throttle position (there are two tracks on the potentiometer - one to correspond with each of the "chokes": the second one doesn't come into play until the throttle is part open.)
engine speed
inlet air temperature
coolant temperature
lambda sensor voltage (when warmed up)
The idle speed is adjusted automatically (using the stepper motor on the butterfly valve) under the control of the ECU.
When you turn the key to ignition on, just prior to a cold start, you may hear the stepper motor open the throttle a bit - you may even see the pedal go down a bit, if the cable is tight.
There isn't anything you can set: if it's all working as intended the ECU will take a stab at an ammount of fuel to inject, and if the engine is warm and the lambda sensor is switching, the ECU will correct this guess to maintain the correct gas mixture into the catalyser (on average).
When cold (ATS and CTS the same value, and no lambda switching) the ECU will juggle throttle position and fuel to give a slightly fast tickover.
On the mono-jetronic the ignition is totally separate from the injection (so no MAP sensor), but there is the vacuum advance to the distributor ot advance the spark on light throttle.
Check the advance cartridge - it fails and you get very flat performance and poor economy.
Give it a really heavy dose of injector cleaner, and a full set of clean filters, including the fuel filter.
That's about it - anyone else care to add, or contradict anything??
John H
Dear John,
Thank you very much, I'm very grateful. Now I have a little knowledge of Mono Jetronic Fuel Injection System.
I also got information that resetting ECU could be done for having best performance.
As I noticed, my Uno have a problem with Throttle Position Sensor, or you said Potentiometer. Could you inform me whether it could be replace by new sensor, or I should buy the whole Carb/Injec body ?
do you have any idea how much does it cost ?
Thank you and best regards,
Hendro. N
AFAIK
The Mono-jetronic can be reset by disconnecting the battery for a few minutes.
Do it while the engine is hot, and restart without touching the accelerator - it will start to "learn" the settings it needs.
If you search this site you may well find the instructions a bit more fully detailed. Might be on the Panda section.
I believe the official line is that the potentiometers (2 of them) are factory set on the throttle body, but ISTR Enzo found some details for setting it up from scratch.
The FIAT cost of a new throttle body probably exceeds the value of the car[:0]
There have been one or two recently on Ebay - went for about 26UKP - but I wouldn't bet on seeing another one.
Best of luck.
John H
My car: Uno 1.1 (1992) with Bosch SPI.
How can I set the potentiometer back to the factory default value with multimeter?
I guess the default value was between 0.190 and 0.210 volt.
I found this in the forum:
http://img156.exs.cx/img156/6016/throttlebody5ey.jpg
Google translator (last few sentence):
To check if the position is correct if you can do the following:
key to driving
bring the lever to the fully open position
press on the pin of the step motor / step until it reaches the stop position all arrears
disconnect the wiring of the motor step / step
This allows for the butterfly in its starting position on the lives of anti stick-slip, the tension that we must note with the key in working position between the pin 7 and ground in this condition must be between 0.190 and 0.210 volts.
Between which pin and ground should I check?
Is there seventh pin in the connector? Not only have 4 pins?
Thanks!
I don't know what the 7th pin is. You are correct, the throttle position sensor only has 4 wires and the stepper motor has 3, injector has 2 and the air temp sensor has 2.
Why do you need to reset the position?
Dan
Hi Dan,
My injector is a used part.
In my opinion the potentiometer wasn't set well earlier.
I want to set the default value (0.190-0.210V without stepper motor).
So, I see the connector of the potentiometer, I see four wires. Which one do I measure 0.2 volts?
Potentiometer is adjusted on a flow bench.
No part to mess around with anyway.
They often tend to wear out and the only thing is to replace them
as a whole part.
To measure it you´ll have to look for noise with an oscilloscope.
I attach a description of the Bosch Mono-Jetronic system. In many settings and measured values ​​are described. The potentiometer setting is also included. Unfortunately, this is Polish language. Anyone who can speak Polish, translate and publish. A google translate helps a lot, but not the best.
  • BOSCH_Mono_Jetronic_Motronic.pdf
