General Anybody know the full list of trofeo components?
project-cinqy
Coningsby, Lincolnshire
Ok, Difficult question this, but here goes.
Does anyone know the full contents of the original 899 trofeo kit? I know they managed to get 65bhp out of the motor, and I'm really curious as to how. I've seen a photo but it's too small to see actual components, bar the big bits obviously!!
Am just curious to know how they did it without turbo's!
Jon+Em
I used to have the information, but it got lost, in the usual manner.
Methinks it was headwork, cam and different inlet. I know the later 1108 had MPi, not the same as the current Sei set up, and they got 110 bhp out of that.
there was a trofeo 899 manifold on ebay the other week.
there was a link of cc forum about trofeo cinqs. have a look on there if not i think arc knows the link.
That link is cento porn at its finest...
IIRC they run 110BHp out of the box...on FIA approved race fuel :)
so prob only bout 95/100 bhp on standard forcourt crap!
I'm not interested with the sporting as ours is an sx.
I'm expecting head work but i'd like to know how? was it a specially cast head?
i mean to go from 39 to 65bhp is quite an increase!
Jon+Em
Probably...the 899cc inlet design is a err....crap to put it bluntly :)
just ever so slightly!
The only way round that I can see is bore it out till it's as round as possible and machine a spacer to go inbetween the head and the TB.
Would drop the hight of the tb as well.
Jon+Em
The Trofeo, if what I'm told is correct, was based on the 903 and not the 899
The CR was raised fairly substantially and porting/headwork/cam/exhaust/ecu must have been done..................would have thought the engine would have been balanced/lightened throughout, don't know if group A regs call for standard issue pistons/rods :chin:
Only difference between the 899 and the 903 is the pistons and bore, heads are identical!
This is the photo i've seen, and i can make out
plugs, ecu, oil cooler, bash plate wheels/brakes/supension, rollcage and braces, seats, full exuast system. At the front I think i can make out a cam, pushrods and tappets. There is a Bob on the far right and the big bulky black thing on the far right looks a bit like an airbox? pluss i found this photo of a sporting trofeo, which seems to show an airbox arrangement that appears based on the 899/903 airbox.
also found one of a 903 which shows the airbox. the sporting appears to have a cone filter or a bell-mouth on, I cant quite make it out!!
Jon+Em
Actually, the difference in cc comes from the stroke and the 903 does run a slightly higher CR as standard IIRC :p Bores are the same.
ah, i thought the bore was bigger! I stand corrected. SO did they just use shorter pistons to lengthen the stroke, or is it a longer cylinder? And does anyone know what year fiat changed to 899?
Jon+Em
Jon+Em
The 899 came in 1993, according to carsfromitaly.com
so 903's weren't sold over here then, if so they'll all be totally dead. shame coz theres a early 93 in my local scrappy with a good motor. Well I think it's 93. hmm will the capacity be stamped on the block somewhere?
Jon+Em
(apologies to myself for going OT)
Also it says on carsfromitaly.com that the stroke is 0.3mm (about 25 thou) longer for the 903.
Jon+Em
Why not get it anyway and get a shop to stroke it for you?
And I think the 903 engine was fitted to the Uno at some point as well.........
project-cinqy said:
hmm. what is entailed in getting it stroked? just slightly shorter pistons? I know that would lower the compression ratio though?
Jon+Em
I think stroking would entail crank grinding. The con rods may need modifying, but I don't think piston mods are needed. Not sure on that one.
It may be worth asking an engine tuner, such as Rob Walker Engineering directly.
Or if you can find a 903 Uno.............................use the engine in that.
