ALFA - An Alternative to the Fiat's?
ALFA Mito Twinair, very tight low miles example
Bought as a sister car to the 2012+ Punto TA that I have owned for 11 years and 70k,
They are the same... Right..?
And as an alternative to a VAG product I tried.. (a failed experiment)
Having owned 2 of the "mk3" Puntos, considering not much really changed between the Grande and the last of the Puntos, I had always wondered about the Mito, it is based on the same car so I'm not sure how differently it drives. I didn't like my 2006 Grande at all, the 1.4 8v is pretty lacklusture and the complete lack of steering feel in Punto's makes for a dull drive. I really like the TA engine in my 2013 Punto but aside from the fizzy engine it drove the same way my Grande did.
I want the Mito to be more involving but I'm not convinced it will (despite the DNA switch), once you've got some miles under it let me know how it compares!
I had much the same experience with my 2006 grande also a 1.4 8v also lacking any power or poise.
That being said the 1.6 sporting was a whole different kettle of fish, much better handling and more power, the cars got a lot more heavier but the engines never really kept up with fiat and they only ever seemed to want to put small low powered engines in them.
When I owned my mk2b HGT i always joked that it had all all the gadgets and all the the reliability of an alfa Romeo but non of the heritage, so it was the worst of both worlds.
I don’t really feel that the alfa reputation is unfair.
I came to Fiat's from the Alfa stable, and my Alfas were incredibly reliable, they're not without their faults, but no more so than any other marque out there, even my Fiat was fantastic.
If I drove any of my previous other cars as hard as I drove my Alfas they'd be wrecked in no time.
My current low mileage BMW is far from reliable, and my Yeti (but that does have 112k on the clock).
If I could afford a Guilia, then I'd be in one in a heartbeat.
A few years ago I bought an Alfa 156 2.0 JTS. When changing the cam belt it was evident that one of the exh lobes of the camshaft had worn though the hardening by about 5mm! A few months later it dropped a valve destroying the engine. They may be part of the Fiat group but I wouldn't have another Alfa.
You could argue the JTS is a GM engine... weirdly all the copious Vauxhall diesels are a variation of Alfa's JTD engine, and in return Alfa 1.8 Ecotec and JTS engines.
TWO Twinairs? You're a brave man.... :)
I like the T-Jet engine in most things, Grandes and MiTos included. Surely the best engine of the recent-ish bunch.
My 3rd actually.. ☺️
Punto, every home should have one👍
Panda, great.. But not perfect 🤔
Mito.. The Jury is out..
Runs like the Punto, but ride is harsh.. And got annoying Niggles to work through
Only had basic FIRE, and a 2018 500
Not a fan of the 500 motor, we are always looking for the ECO. Button to find the missing power 😔
Im sure lots of subtle differences. The Giulietta and the Bravo are similar but actually some substantial differences. In most cases I love both Fiat and Alfa variants. Alfa do know how to boost feel good finish, but not at a cost Im prepared to pay. Giulietta has independant rear suspension, but the Bravo semi independant system worked pretty well and was simpler to maintain.
Nowt wrong with a Twinair, keep on top of the maintenace so the multiair unit doesn't go bad and they're pretty good.
Miss my luminous green Punto TA for its engine, rest of the car not so much... Wish Fiat had put it in something remotely involving to drive
1st proper update
Had the supplied battery checked
(seemed OK.. On their meter)
Seems to be a little happier, 😊
Runs well, but pings errors on Start. Up
Working through the basics 1st 👍
Got the tracking adjusted too
Had felt "planted" , but steering wheel tilted left
Now tracks straight, corners well, but seems twitchy ( like the punto.. )
What toys does it have then? I had wanted the Brio pack on the Punto which came with more or less everything but the Twinair was its own trim level so couldn't have both!
Here goes.. (There will be more..?)
Alarm, No idea.. 😕
Seat occupied indicators.. In Green near rear view mirror
3 mode DNA .. rather than ECO
Bonnet open alarm! Discovered during battery testing😉
Window switches are at REAR of door card.. Rather than front.. Set. Up for Reclined seats ( contortion required if you have ShortLegs 😳)
Windows drop as door opens (, to clear roof seals.. much quieter at 70 mph than the Punto..) THOUGHT THAT WAS MY 1ST FAULT 😁
I'm learning..
More spec updates as I learn 😆
