Technical 3L fiat ducato comformatic gear box oil filer plug
Oweny
Rivervale
I would greatly appreciate if anyone could tell me the location of the gearbox oil filer plug on my 2012 fiat ducato 3L 6 speed comformatic gearbox on my motor home.
With my thanks. From a new member.
Are you asking about the oil to lubricate the gearbox?
Or
The fluid for the robot that operates the gear changes and clutch?
M40 gearbox Filler & drain plug locations
Or
Thanks for your reply. I’m going to gearbox oil change and l’m having trouble locating the filer plug. It doesn’t have a breather cap on top of the gear box like I’ve seen on U tube.
Very helpful pics from Hugh. The angle of the pics is 90 degrees rotated due to being from a manual showing the gearbox removed from vehicle and bolted to a repair stand.
Do not fill all the way to bottom edge of filler hole!
Drain and refill with correct volume of correct oil.
