Panda (Classic) 3 Sisleys and a 'HOLE' lot of TLC
So this weekend has been a rather busy one. After an impromtu ebay purchase, me and the old man made three 180 mile round trips to Gloucester to retrieve three Sisleys in various states of neglect.
1 red H reg with 95k on the clock and 2 blue F regs with 60 and 65k on the clock.
All have been off the road for quite some time and there are no documents to accompany them, but at £600 i thought it was a bit of a steal.
One of the blue ones has taken a nasty hit, and the sills are completely shot so the body is a no go. It still has the engine, gearbox and running gear. The other has a taken a shunt to the front left wing but with a strong amount of tlc could pass as a rough and ready green laner. With no gearbox and a pretty sad looking engine, i'll likely use the crumpled blue as a donor. Saying that all of the cars are non-runners and without having had a proper look im just speculating.
Now the red one is definately a feasible project, with 'fairly' solid sills and no major dents in the body work (despite the awful doors) she looks to be the bread winner of the lot. The inside isnt so 'wild' either.
The majority of the weekend has been spent loading, transporting and unloading, as well as cleaning out the garage for the new inhabitants so ive only managed to take a handfull of photos.
So the basic plan is to leave the red one for the time being, since she is the least desperate and doesnt look so much of an eye sore on the drive. My priority for now is to strip the blue without the gearbox and assess the body properlly to decide whether she is a keeper or not. If so ill be spending some time on the welder, scraping all of the broken bits and stripping the second blue for all of the useful parts (not keeping my hopes up though).
I'll try and keep the thread up to date with the work and have some more detailed pictures up next weekend after ive gone over the body with a screwdriver and hammer :D
Got these 2 babies for £55 IMG_1487629487.130129.jpg and these 2 pairs £14. IMG_1487629533.673432.jpg should get them tomorrow
Got both deliveries see you tomorrow
We have looked at making a drop down hanging point as realising the longer shackle effect as a tee section connecting to original position and an exter fixing along the chassis rail. But haven't had chance yet to get some 30 x 1.5 wall tube
Also a double Joddel would be require don't know where my fly press is so forward and onward But temporary
Have you consider adding extra leaf?
Accorrding to 1st shackle effect spring rate will softens, not masively but still.
Are you planning to drop down top shock mount? or going for beefier shocks?
Haven't considered adding the extra leaf, although doing so would probably be wise if we are going to obtain a set of stiffer front springs.
Not planning on dropping the top shock mounts. We currently have approximately 80mm lift all round. +50mm front leaf spring mounts, +50mm hangers, +30mm axle spacers. +36mm shock spacers, +50mm hub carrier extensions (with +50mm control arm mount point drop and +40mm extended control arms)
Looking potentially to use Rover 25 springs or Feicia springs as per your recommendations thread. Although we are using standard shocks so are concerned about dead ending the shocks on extension.
We are adding the 1.2 engine which will add a small amount of front end mass.
As above Adams last post sorry Steve
Have looked at a panda this week with the longer shackles it's Owner had placed coil spring above the axel to the bump stop position a Nice's soft spring would be required say 8mm x 120 mm bolted in place with u bolts
This was my initial set of
Fiat 124 Familiare (estate).
unfortunately during the lower eye welding on process ( i did not use lower cup of std 4x4 shocks) i've burned thru tiny hole. They were oil only so not much happend but some spatters got inside and seals gone busted pretty quickly.
They surely made rear ens stiffer and give better feel in corners. This pair was pretty cheap - less that £20 but hard to get. So I went same direction and ended up with Delphi gas shocks (£19) from Lada Niva and used lower cup of 4x4 shock. Extended bump stop keep the shock safe from being fully closed and loaded, while there is far more down travel.
Second from top is 2wd one
We've got 2wd shocks and added a 40mm bumpstop rubber extention to the strike plate
I can sell you set of these if you want - I just don't like them. The is small bump stop, spring and lower locator pad.
They are the Ostrav - Italy or somma like that
Yes them the ones. I seen here
Make sure your rear diff input shaft angle is at right/ same angle. Not wedge type spacers shouldn't be used in more than 10mm. Axle isn't located at middle of the leaf.
Extending rear shackle by 50mm does not necessarily give 50mm lift - dropping top shackles mount would do.
Shackle normals gives 60%.
Looking good.
Looking good.
You perfectly right the mean angles should be the same. IMG_1488172639.861928.jpg
As per detail otherwise vibration and noise leading to ware of the U.J will occur. It is also important that the yokes of the drive line counter each other. This mistake can also be made if the yoke Is removed from the spline for maintenance
Also if the diff is lowered this increases the angle which will have the same effect , so simply fitting a spacer under the spring will increase ware and then take the U J. Out of its design range the transfer shaft C j to Uj should also be lowered or possibly tilted too with a rotation of the axel to compensate
Ideally a longer final shaft and shorter first shaft repositioning of the linking shaft closer to the box would be the solution Costly though ! (2 x balance )and gear linkage fowling !
The document is here
http://www.4crawler.com/4x4/CheapTricks/Driveline-101.shtml#SingleCardan
Very interesting
As previous
As previous
Sorry for duplicating, it was quite late yesterday.
Fly Press are the best, unless you'll loose track of 'the ball'.
I must get under mine with protractor to double check that mine are still lined up and replaced rear UJ as uit had play from day 1. Got some cheap ones from ebay and can't decide is it worth to get some branded ones.
Forget the protractor use a sliding bevel from engineers or joiners kit check both. Is slightly out not to worry as load dependant then read from the sliding bevel gauge the mean angle
Done it again as above. Ha
