Keith Spencer
I am a little confused. I am trying to find and check my ambient temperature sensor!
I am reliably informed that the ECU uses this sensor and will not proceed with a normal DPF regen whilst driving, unless it is operational.
Now I know it's supposed to be in the drivers side wing mirror and I have removed the internal door trim to access the wire connectors and my ducato only has the 8 wire connector for mirror setting and heating, the 2 wire temp sensor connector in the harness is not there at all? I have checked the passenger door mirror in the same way with the same result!
Does anyone know if the sensor is positioned elsewhere on a 2009 ducato bessacarr motorhome?
