meshgrid
- Joined
- Aug 11, 2012
- Messages
- 33
- Points
- 87
hi,
i got a 1.2 16v engine for my seicento, and i want to refresh it before dropping it in the car.
is there a way to tell size of the rod/main bearings from the markings on them? for example, a rod bearing is part nr 46776774, and on it there are also markings CL16 207. is the oversize (STD/0.25mm/0.5mm) usually only printed on the bearing and the print is washed away with time? (in the end i will probably have the crank and the block measured to determine the needed bearing size, but i'd like to know anyway)
thanks!
thanks!
