Parts Needed
Time required: 81 mins
Parts Needed
Mandatory:
1x Sump suitable for mk1, you can also put on a used sump but that will take more time to remove and clean old gasket sealant from it
1x High temperature gasket sealant
1x Cloth
1x Flat screwdriver
1x Wooden Wedge
1x Spanner/socket wrench in the following sizes:
10
13
1x Allen key for socket wrench or normal one, size 12
Optional:
Since you have to drain the oil anyway i advise to change oil + oil filter aswell, unless it was changed recently
1x Wire brush for drill
1x Battery drill
1x Brake cleaner spray
1x High temp spray paint
Sump tightening torque: 10nm
