Getting started
First, make sure your door opens. Wind the window up fully. The door trim must be removed, to take it off you need to remove:
- the elec window switch or wind up handle,
- the door handle (2x 4mm allen)
- 3x 5mm allen bolts in the centre of the trim,
- 4 phillips screws on the bottom and
- 3 at the side near the wing
The trim is held on at this stage with 3 clips at the end and the top piece. Prise off carefully, they tear easily at the top if taken off wrong
