Connecting them all up
In your boot you should now have a:
Red Power Cable
Brown Ground Cable
Twin set of RCA Cables
Small Blue Remote Cable
You now need to undo the screws / allen key connectors to allow you to put the wires into the correct connector block. You will need to use either wire cutters or a simple cutting knife like i did. Trim the plastic coating around the wires so only the copper is out, do this about an inch so you have an inch of copper wire at the end of the cable.
This will allow you to insert the copper wire into the connectors and redo them back up one by one.
Once this is done your all set to go. Make sure you check all connections are solid.
Check that all fuses are ok and inserted correctly and set all of the settings on the amplifier to 0
