Final results and other thoughts
Final results, and other thoughts
-After a long time working on this, and many setbacks, this is the final result:
This guide is made for a specific type of DRL's but should work with comparable ones.
I also came to notice that the DRL's I use don't have an 'E' marking, or european 'CE' marking
Also: Never forget to use sufficient vaseline after drilling holes in the chassis to avoid corrosion, and don´t forget to seal your DRL-units watertight.
Thanks for reading this guide, hope it helped you.
Cheers,
Allard :yeahthat:[/SIZE]
