Lexus CT200h Sport
My fifth car and hopefully in the running for the longest-owned title...
Finally spring is here. It's now somewhat warm enough to be outside for prolonged periods without two coats a hat and a scarf. On Saturday I changed the oil and filter on the CT. Using one of those containers with a little catch surface on the side... but to my disappointment, as the gushing stream of old oil blasted out and didn't hit the little intake hole, it splashed all over the container and subsequently the ground... the messiest oil change I ever did. More than half must have ended up on the ground.. thankfully we have an excess of sawdust from all the wood working machines around that soaked it up. Other than that... it was a nice enough experience. First 'garage day' of the year. We have so many more nice tools now for these things, a big torque wrench to eliminate any doubts over tightening, a special little (mandatory) Toyota fitting that grips the oil filter housing without hassle etc.
After that, I spent a few hours tracing the shapes of the only remaining felt padding insert left in the car, mirroring it for the other side. Then the front doors... tracing it out with a sticky note and a pencil. Third attempt for the front and I got it spot on. I made a mirrored one only to realise that the passenger door card doesn't have that little compartment and has a totally different leather handle... funny little car this is. The Amazon special felt / insert is about 3x thicker than the factory stuff and sticks down so hoovering won't suck it up - I presume this happened to the originals. Can always be ripped off and re-made if for some reason I need to get into the door internals. I did the cupholders and door bins as well, and what a difference is makes. The keys and anything from a packet of Halls, used to rattle when set down. I suppose they cut corners in a lot of places on the CT.
I learned that the oil dip stick, even at the 'LOW' mark is excess to what is actually the required amount for the engine. So this time I filled the level to around mid-way to avoid over filling without a doubt. I'll give it another check this evening. Seems safer this way. Though since I've had the car I'm glad to say that, just like my Panda's, it barely changes the colour of the oil - it goes from a clear 'over hydrated' honey like colour to a normal honey colour on the dipstick over the six months. And it doesn't lower or burn anything so far either, although none of my cars have done that thankfully. The engine isn't the worry with this car... it's everything else attached to it!
Still using 'the good stuff'... maybe the promises of special additives will do something over time...
A photo of the new brake booster they fitted... I found a couple of the factory plastic caps covering the brake line holes rolling around in the engine under tray...
Nearly time for the annual engine bay detail, but it's not gotten too dusty or bad since last April...
Last-last Friday on a day off I spent it just hoovering out the car (first time since November), cleaning the plastics, the upholstery, leather (and fake leather) bits all balmed, glass cleaned. I forgot what an absolute dream coming out to a clean car in the mornings is. When I did the oil change just this weekend past, I gave it another quick hoovering just to stay on top of it like usual. Never letting it fall that far behind again. Putting away a tenner a month in a jar... so that come December, there is £120 sitting there to have it fully valeted inside and out mid-winter... why not?
I think in my last update I said something to the effect of this car being very boring / not needing much with the exception of some damage repair with the tyre sensor / wheel bearing on the same wheel. Well, I spoke too soon.
Literally that week in January, I got a few warning lights on: traction, ABS, handbrake (red) and (amber) lights intermittent. But a few days later they came back to stay. I also could hear an electronic charging sound going mad at the same time. I lost brake assist / ABS and the likes but was still able to drive the car. I plugged in the Autel scanner, it showed various codes surrounding there being 'dirt or foreign objects' on the rear right speed sensor - same side as I had the broken TPMS sensor and bearing replaced on..
Headed into the dealer I bought the car from (a Toyota dealer) with what I calculated to be two days left in my '12 month used car warranty'. I asked them to check first if I was right so that I didn't waste their time so much as explaining the issue if it weren't to be their problem. To my surprise they told me the car has warranty until July this year, so not arguing with that. Booked in for an inspection. They suspected the wiring on the speed sensor, as opposed to the sensor itself which is inside of the rear bearing on these cars.
A week later, this was fitted but it didn't solve the issue. They tried a Corolla bearing that was in stock, which apparently fits but also did not solve the problem. At that point they asked for more time with the car and gave me a not-so-bad Yaris courtesy car. They followed the wiring on up the loom, well, actually just replaced the loom (interesting how they don't spend time finding the needle in the haystack of wiring issues, but who can blame them!) but noted no signs of external influence or damage. New loom, still issue present. Next step being the master cylinder / 'brake booster'. A Hybrid (and I suspect EV) specific part for replicating the vacuum function of an engine for the braking system when the engine is off - or, all of the time in this setup maybe even when the engine is on. It has four little tubes coming out from it and appears mated to the master cylinder / brake fluid reservoir and I think only on the CT, it is also attached to the control unit too making it more expensive when it fails. And fail, it does. I could see online that there was a recall ending in 2021 in the US for this part interestingly, but for 2013 and 2014 model cars... and many other threads of people with older CTs having major brake system parts replaced much later on in the life so I trust this is something that might be a 'when not if' job on these CTs. So much for 'reliability' eh?! Maybe it's 'cope' but at least if this happened at 14+ years old, or in another 80,000 miles when the car is worth nothing, at least it's something that won't stop it from driving... whether or not it can pass an MOT without the ABS and traction, is maybe the issue there.
I picked it up on Friday. And sure enough, it feels and drives like new - absolutely as quiet and smooth rolling over the ground as I felt the first time I test drove it. I actually got on quite well with the Yaris courtesy car, 2024, 1400 or so miles, self-driving features and the newer Hybrid system. It reminded me a lot of my 2017 Panda in terms of how fresh / new it felt, the size class, it was delightfully easier to park with the same spaces in the city I park the CT in always having a bigger margin of space. I could go back to a smaller car tomorrow practicality wise. What I did notice was you can hear and feel the hybrid kit more, and the engine coming on and off. Not bad or alarming, but you actually notice it. The whole frame of the car has a little shudder when the engine kicks in in a hurry. Somehow, the eCVT gearbox on the Yaris manages to be quieter. Either they have improved the design since the 2010 CT iteration or the much smaller lighter car doesn't strain it as much, I think the Yaris is 400kg lighter than the CT which is not nothing. The fuel and mpg on the Yaris also reminded me of the Panda days where you could forget it had a fuel gauge and it rarely bothered you with a fuel low light. My 2016 era estimation that 'for everything a small car lacks, it makes up for with something else' is quite true. The MPG, ease of use, and all that are also not nothing. For a lot of people that's well worth it over a gas guzzler and sound deadening. And that's not to say the CT is bad on fuel, but relatively to the Yaris or any Panda I've had, it is noticeably worse and you do notice it money wise if you care to look.
I am so glad to have the CT back though. It feels solid to drive, it's very quiet, the controls are right at your hand, the way the needle on the speedometer rises and drops even feels more relaxed and on the drive back from Belfast on Friday night, I was able to turn off the screen and dim everything right down, turning off the ambient lights and footwell, and completely focus in on the drive with only the bare minimum interruptions from the car. While it is just a Toyota with a bit of fancy bits thrown here and there, they definitely made the right decisions and you do feel like everything has been intentionally done to try and 'delight' you. For all the hassle / expense, it can feel redeeming much of the time.
The Yaris gave me reassurance that the now coming 8 year old Hybrid battery and motor on my CT are actually in optimal condition, I always presumed that with the age and sitting around this car did, that it was likely below average in function. That's not the case, the Yaris with its much lower weight load and new, fresh batteries and motor and next-generation system kicked in more I would say and earlier and seemingly didn't stay on electric up hills so that's nice to know about the CT that it is operating as new in terms of the electric part of the drivetrain.
What's the plan now?
If this had have happened outside of warranty I'd have been in a really bad position. I'd have been paying Toyota (or worse, Lexus) to play part roulette with the sensor wire... bearing... loom... and then brake booster probably over weeks or months before getting a resolution and completely derailing my saving / investing in other areas just to pay for that without resorting to debt. A forum member here suggested that I take advantage of the Toytota / Lexus 'Relax' warranty. Meaning if I let Lexus service it they add one year / 10,000 miles of warranty to the car until it's 10 years old or 100,000 miles. This would cover me for all the major non-wear and tear repairs. I spoke with them on the phone, they did indeed confirm that this brake booster and related parts would have been covered and had been covered on other cars - no arguing or hassle. That makes, what I previously felt wasn't worth the money, worth the money. Sure, there is the argument that it might not go wrong but I could have said that after the TPMS or the first bearing issue... then this. So the smart option seems to be for the next two and a bit years to just take the financial shafting of dealer servicing at Lexus for that last little bit of warranty and after that, leave it up to fate. £330 this year... £585 next year.
It might be further 'cope' too, but given the shape of this car from the last owner and what I suspect was a rough couple of years for it, the bearings and whatnot - especially given that they're both on one, the same side, seem to be from misuse rather than some shortcoming in design or quality. Since the other sides show no signs of issue either, that's what I believe currently. Perhaps now the car will be fine and free of any repair needed for anything like this.... but I'd better not speak too soon like last time.
A year in... 9th January 2024, bought. 17th January 2024 collected it and parted with the Avensis. Mostly over concerns with its BMW diesel engine and reading one too many stories of owners with those having them 'go bang' between 150-200k miles which is respectable in the BMW world, but rookie numbers in the Toyota world. Still, if nothing else Toyota should be about reliability - in the absence of fun, performance, sport and especially 'character' in the way a Fiat would be. So to own the Avensis and benefit from none of the reliability, and also none of the other measures of a 'good car' could sum up the main reason for jumping ship.
Buying it
The CT I have was really just in the right place at the right time, at around a grand less than it had been six months prior and was sitting around for a long, long time at the dealership. To look at it close up as well, it was clear to see why, Long, big scratches (sometimes deep) along the side, the bonnet. Chunks missing from the tyres (one original by the looks of it too) and as of last January... sprouting light surface mould in the back seat. It was rough. I didn't think that the main franchise Toyota dealer would have a car on display in such poor shape. Though as my Avensis was technically 'fine', I had a good battery, new Michelins put on etc, I was certainly in no position to be forced to give it up. This afforded me the ability to take my time, try and get a deal and use the fact that they can't get rid of the CT, and its condition, as bargaining chips. This, combined with some trouble I had with that Toyota dealer got me a pretty decent price on the CT as they truly did want rid of it. They cleaned up 95% of the scratches / roughness through a decent polish with two notable 'very bad' ones left on it, one is a line up the drivers door near the top but very minimal compared to what it was. One is a deep scratch right on the bonnet that is in your face on a bright summers day, but fairly hard to spot the rest of the time. It is certainly the least 'good condition' "newer" car I've had and arguably, each car I've had since that pristine 2 year old 2017 Panda have gotten slightly worse. I've concluded that it's not worth sinking money into and is simply worth living with, but I knew that I'd need this mindset from the first look at the car - and thankfully, have had no regrets since.
Positive aspects
Things I love about this car - it's a tad unusual looking at the back, which is something I thought of the Panda and quite learned to like about that despite (with both cars) always thinking the back ends were 'ugly', I've come around to liking these designs that stand out and/or are unique! The electrical side of the hybrid system is so, so incredibly smooth and quiet and kicks in a lot more than I'd have imagined. The system works as good as new, truly. I thought the long periods of being for sale in this cars history might have particularly ruined the battery but it's still holding up brilliantly. It wasn't until my experience with the Grandland that I realised just how quiet / smooth and comfortable this setup of moving a car truly is as I put some of it down to it simply being an auto but quickly learnt they are not all created equal. You feel nothing, hear nothing other than a grind of the metal parts moving off for a few seconds. You don't even feel or hear the engine kicking in at all, just a little green light letting you know it's off which does its own thing.
Parts and Servicing
I love the working on this car too, every service item I've done so far is so easy to access, every bolt and cover comes off with minimal fuss (can't do much about the dirt falling into your mouth though when under it...) and nothing is any more complicated than it needs to be. Buying genuine parts (and even fluids) is also fairly affordable, everything is often stocked and unlike with DS or our old local Fiat dealership when it was here, the parts / service people don't look at me like I'm stupid for buying genuine parts. I will admit, Lexus leave a little to be desired compared to what I had hoped but then as a third party customer who bought an older car used from someone else.. perhaps that's their issue with me. They wouldn't quote me for parts - directed me to the franchise separate parts line (until Lexus stepped in and reminded them that as a dealer, they need to operate a parts service for customers of that brand....). They over charged me last year versus the website / app pricing for the hybrid check, but this year, again, Lexus keeping them right... They wouldn't quote for just an oil and filter change, said it's just the two package levels of service they do. This is in contrary to, a time I called up a BMW dealer here to check the price of genuine brake parts for my cousins 4 series... Not only did they take time on the phone, attempt small talk as they waited for their system, offered a range of parts - knew inside out the various options / specs, told me how to check which kind was fitted, AND, offered to have them delivered to his house the next day by the van route of parts they send around this part of the country... That really did blow me away. To those with more money than sense, if they enjoy a BMW and can afford to throw money at it and have that level of service, I somewhat 'get it'. But with Lexus, they suffer a bit from what most businesses in Northern Ireland do - a severe lack of competition and 'only one' syndrome, being the only dealer here without needing a ferry ticket. It needs this annual hybrid health check done, which I had done last February and is now due this week (early by mileage) and I'm having it done for £60. Given the savings on brakes (I've heard tale of 200,000 mile Prius with original brake parts online!) I think that, and the extra few litres of coolant for the hybrid cooling system aren't really an issue as you work out still in the positive after netting them.
Bad aspects
Other than the fact it's not a Panda, or an Abarth with the sheer love of the ownership experience, the extra participation on this forum which that would bring, and all that jazz, there's really little to fault. It's not a fast or powerful car... but it's the fastest and most powerful car I've owned. The gearbox can be noisy when floored, but then, as I said, it's so incredibly smooth and in fairness, the level of pushing your foot into the metal floor needed to make it make any kind of 'bad' noise is the sort of driving that will make any car or engine rev up to excess before moving gear I would say. The boot is quite small, and the shape of the back of the car is reminiscent of the Fiat 500 in how, they've shaped it for style, and totally wiped out quite a lot of practicality that the footprint and size / weight of the car could provide. But then this was, in the designers eyes, the car for that to be appropriate for as the Auris and Prius existed where practicality or further efficiency was preferred. The original touch screen interface is more intuitive and responsive than the blue one in the Toyota (the 2015-2018 system for Toyota) and initially, this was nice. Though the Toyota had this online subscription option that could show petrol prices, traffic and weather etc on the map which was way more convenient than I'd thought (the sum of the parts was greater than the gimmick I perceived it as in the brochure). I missed that in fairness. But unlike that system, this one had an affordable Chinese aftermarket solution to add CarPlay and Android Auto, since then, I've been enjoying a top notch in-car-map / communication experience. There are no rear cupholders which can be a practical issue. There is barely any room for tall people in the back also though I don't have many people in the back these days.
Will I keep it?
The longest car I've owned was my 2005 Panda - October 2015 until July 2019. Three and a half years. I'd have kept that longer had it not had the stalling issues. That's the record. 2017 Panda - 1 year. DS3 - 1.5 years. Avensis 2 years. Statistically... 2.5 years?! I think this one will be the forever car... well, nothing lasts forever. But until it's either written off, or has a major failure, or most likely, has a moderate failure or impending service item that can't be justified by market value or age of the car.... Or if something like the bodywork gets particularly bad... or engine starts overheating or something like that occurs as an outlier, making redundant the great shape of the other parts. I think this car is here now for that reason.
Why though? What makes this different? Honestly... finance. I'm bloody stupid for that. Lost a bit on the 2017 Panda... rolled into the DS3. In fairness, I got back more than I owed in 2021 on the DS3 that sort of reset it. That was also an attractive 6.6% rate because of Covid. The Avensis.. some stupid rate despite me at the time having 20 off a full credit score... Still not too bad all things considered. But the loss on it, rolled into this car at a still stupid rate which was standard in most places in NI last year (probably still is) meant the total sum of what I've got to pay for this is multiple thousands above the value of the sale price. I'm quite good with money but this is certainly poor form and costly. I've decided I never want to do car finance again. This year (2025) already I've just decided to pay off upfront the next few years of the CT saving some £3,000 overall in interest. And a couple of overpayments this year and that'll be it, no more finance. On this... or anything. The money I would have paid per month will go into a savings account and grow. And when I need a new car, it's quite likely there will be enough there to just buy one used and forever be rid of the drain on the wallet that is car finance. At this stage I've experienced enough of cars that I think I understand the value proposition and the personal sacrifice financially needed, as well as the mental turmoil when something goes wrong... or some place repaired it poorly... or insurance are being the ****s they are globally known to be during stressful times. I've just decided that... none of it is worth it. Toyotas outlast the owners quite often but none of them have been able to take them to the afterlife...
What's next
The future. Many years with this car I hope. And when the time comes, it's a two way junction..... A used Panda (new model) or a used Lexus LBX or Corolla. That's it isn't it? Either I get fed up with Toyota and go back to a Panda with a new model that overcomes much of the nuances with the outgoing one. Or I build on what will hopefully be a steady, dependable time with this comfortable, hassle-free and cheap to run car with another one. Time will tell. I will be sure to write the next book-size instalment of my car journey on here for anybody still reading!
Well, finally went and did it over the last four weeks. Put heated seats into the car, went fairly smooth, think I only (permanently) broke one clip that I couldn't replace and nothing is 'sagging'. The seat heaters are a great job, though the switch feels cheap it's quite out of the way. Though it's green lit, it's very much retina-burning Chinesium grade lighting. Though very grateful to have them in these ever-colder mornings.
Ordered a CarPlay head unit that works with the original factory screen / system at the same time - despite never being an actual option from factory. Impressive to me that someone has figured out how to develop this sort of thing, I see they exist for most every outgoing / relatively modern but not quite latest car brand nav screen units. Fitting it was easy enough, something about the Lexus I've noticed is everything - from the seats, to access panels, to interior trim panels / clips, all seem to pop off reasonably and go back together very securely, whereas my Avensis the second you touched or tampered with something, it creaked or never sat quite right... maybe it was a skill issue, but so far so good on this car. It's a matter of connecting up a very detailed / confusing wiring harness which jumps in in front of the various connectors going into the factory head unit and screen. Some (many) wires and connectors are deliberately left hanging or unused when used in this application, maybe they fit a different variant of head unit or something. There is a multi-switch which needs configured based on the kind of controller you have... mouse pad, rotary dial or joystick, naturally, this is covered in the manual provided but used the exact same image of the rotary dial for all three switch configurations.... so once all was installed, and the visuals were off to the side a bit, I had to try the other combinations until I got it right. I think this was to fit other Lexus models with wider screens which have the same as my screen, but some sort of information panel to the right.
End result... after a bit of tweaking the harness, switches and then some software settings for sound, and it all worked. Hold menu to go back to the factory system... controls all worked, steering wheel controls, screen interface properly scaled, responsive (about as responsive as the DS3 CarPlay was - good for the era of system though lacking compared to the latest and greatest system). First time I've used CarPlay without touch input, but it's much better not having to hold your hand up while driving all the same once you get used to the controls. It's quite nice, I must say.
I've got the holy trinity of car features now that I've sought for a long time, the most complicated being automatic gearbox, then heated seats, and now CarPlay. Hopefully everything works and the car lasts for a long time now. I can't see myself putting any major money into it now except for repairs and servicing.
Would I go back to a Panda tomorrow? Absolutely if the price was right and other factors made sense. It's a little annoying to think that a decade ago, before the 2016 facelift, you very much could get an automatic Panda, with heated seats and plenty of aftermarket units back then that you could have added CarPlay with. Frankly, the smaller size / simplicity and lack of refinement that I might be used to now, I could do without really. The good news is, the next model will have all of these features (and much more), so for the future, who knows.
That's it for the Lexus now until the January service.
Nothing much to report on for the summer, other than enjoying the Michelin Pilot Sport 5's! Though there was quite a noise coming from the front right wheel. Suspected a bad fitting job for the longest time, after about 3 re-fits we ruled out tyre issues. The TPMS (pre-existing issue) sensor was fixed, but had been bouncing about inside the wheel... though the noise persisted, but only over 70mph and in the dry. Turned out to be a wheel bearing on the same front left wheel... I suspect some sort of damage or heavy impact before I owned the car is what led to this as so far, no other TPMS sensors have had low batteries or issues, nor have any other bearings gone bad - and it seems to be a pretty rare part to go wrong on Toyota/Lexus cars this early outside of inflicted damage. Thankfully, both jobs covered under warranty using genuine parts. That was summer.
Now, coming into Autumn I've ordered this little £150 job from the internet that adds Apple CarPlay to the factory screen. The factory interface is an improvement over the Avensis, works well / simple enough and responsive enough but definitely outdated and could be better. So CarPlay will put it right and ensure it stays up to date over the years alongside iPhone software updates - can't go wrong with that. As a bonus, it's wireless but personally I don't see the fuss in that... having the phone charged rather than draining faster seems more logical to me.
Also ordered heated seats, the same old kit, though I'm doing the research to be able to hook these elements up to the factory switches / controls - but if not, as a backup, found these little standard Toyota size switches I can put into one of the blank plates down by the drivers footwell - my fairly basic model misses the controls for the heated steering wheel.. lane keep... heated windscreen and parking assist! Looking forward to this coming into the winter. Third time doing the job now...
Everything (from doing my homework and exploring the wiring / connections) on this car seems to come off easily, without struggle and click back together. Comparing this to the Avensis (same maker / construction for the most part) I notice Lexus put much more into the structure of the seat (metal bars to stop side parts from sagging) and things like double sided tape along flat parts of the upholstery which I guess stops it from looking bad with age. The connectors holding in things like the centre console / dash sections are the same as the Toyota, but with an extra thick sort of fabric piece intertwined into them, for anti-vibration / creaking and rattling. It's quite cool to see, though it looks quite simple and inexpensive, I wonder why they wouldn't make this standard on most of their cars. Contrasting with an Audi A5 tutorial I watched to help a friend, where taking apart one door required a degree in electronics and 25 years experience in the attic insulation industry about pushing things in and making them fit to get it back together! Quite glad that the only differences in a Lexus are still fairly common sense, non obtrusive or destructive to work with.
The next investment will be a set of steel rims, Toyota themselves sell these for £260 for a set of four. The killer being having to buy four more, dedicated winter tyres to put on them. If Michelin... that won't be cheap. Thinking about this one.. We get bang on 6 months per year of 7 degrees or under, and 6 months of 7 degrees and above so going by the book of winter vs summer tyres, we truly do 'need' them as much as anyone, maybe more so given our mixed climate versus an always warm or always freezing country who can safely use just one set all year. I think it worthy. Just hope if I invest, that a future car will share the wheel size so it's not a lost cost.
MPG floats around 45 driving a mix of normal and hard and on fast roads. It can easily get above 50 but you need to really drive gentle and not be afraid to p*** off the people behind you, but I can't bring myself to do this unless on an empty road where I can afford to p*** around on my own accord.
Anyways, the Lexus certainly lacks the character of my Fiats but as a car, it does its job, with little fuss. Pleased to report that the dealer, nowadays, also is doing its job with little fuss too. The experience has been quite positive, it's a shame they haven't really built anything as a direct successor to the CT. ..Tried to help my friend with the 2018 420d to find a new car, and looked into some of the 3 door Lexus models... they're getting on a bit now compared to the latest German competitors that he's into. He doesn't want an Audi because of VW diesel issues and quality, he doesn't want a Mercedes with a Renault diesel engine either leaving just another, newer BMW as his likely choice. Shame I can't find anything other than crossovers from Lexus, seems they are happy to continue with being an affluent-OAP brand now that they're dropping most of the non SUV things - like everybody else :-(
  • Like
Reactions: varesecrazy
The handover from the Avensis… Much smaller but much more sensible size for me.
Pretty awful weather to be taking delivery of a car on… snowy / icy
First snow-foam wash with this car… AutoGlym’s Polar series stuff is decent! Took a few weeks to get the cobwebs from a 6+ month sit around gone…
I ordered this ‘special service tool’ AFTER realising I needed it… luckily managed to get the old oil filter off without damage. Prepared next time…
I always thought the CT had a really dated, ugly looking interior in any photos or reviews I saw of it over the years. But the first time I sat in it in person it did feel much better than I expected.. Everything is laid out really well, and everywhere you come into contact with (knee, elbow) has a little stitched soft fake leather part that feel cushioned. The controls are quite nice to interact with as well, although a lot is shared over from the Avensis such as window controls, stalks etc.
This rear part is definitely the most unique part of the CT’s shape. Again, I always thought this was really ugly and awkward looking online but it blends in easily with the black. It has grown on me. My Panda’s had a unique third side/rear window design feature that was important to its overall side profile / look and the parallel with this is something I quite like now.
Some photos of clean sills! Hassle of a job but one that makes stepping into the car a pleasure for a couple of weeks..
So, this one was a disaster waiting to happen… Taking a CT to the beach in general was a stupid idea… taking an automatic car to the beach, probably also not a good choice… The Michelin tyres made for the road / smooth by design also didn’t help. Ended up getting grounded on the sand and had to be pulled out by a Suzuki 4x4 with huge tyres! Nice guy though, lesson learnt. The CT doesn’t compare to my old Panda’s which could show up most other cars on the sand!
Some photos of a wax using Turtle Wax Graphene infused liquid wax.
Engine bay, post quick little detail… No, not the ‘hold a pressure washer to the engine’ idiocracy! Mostly black trim gel … lol
Took this to show a friend of mine (who has a gross misunderstanding of how the Hybrid system works, having read about the gimmicky EV mode) to show that quite a lot of the time, even at higher speeds, the car can just switch to electric for prolonged periods when demand is low…
The only real ‘big’ investment I’ve made… Michelin Pilot Sport 5’s. Absolutely tyres, even on a slow car like this one. They corner really well, I think the weight of the car with the batteries etc helps throwing it about be more fun than you’d expect. These tyres definitely will never reach their limits on this car, but that’s not so bad. Debated for a long time over sticking with the factory Yokohama’s but they were so hard to source that they essentially cost the same as the PS5s. The sidewalls have this funny little dark area that if you touch it, feels like velvet.. of course that’s a gimmick on a tyre but when nobody’s looking I usually give it a touch… I know, I’m weird..
- End of January, major DIY service
- Mid February, one of those Hybrid Health Checks, £70. Passed / no issues found, breathing easy
- Late February, DIY brake fluid (never had time on the January service), no issues, didn't need to remove the wheels for the last two sides.
- Late February, Ordered and replaced some dirt-seized / broken plastic clips under the car
- Early April, idiot in motorcycle decides to drive into the back of the car damaging light / bumper, repaired with genuine parts at no cost to me.
- May, passed MOT no issues or advisories
- June, ordered four new Pilot Sport 5 tyres - can't wait to get them on and take 'em for a spin. Long debated getting Cross Climates but settled on getting good summers and then next year getting good winters as we literally have 6 months of over 7 degrees and 6 months dipping below it regularly.
Planning to do a 6 months / 5,000 mile oil change in July (time and mileage is lining up nicely for that) using the proper oil / filter. £100 here and there to be a little over the top can't do any harm. That'll do it until next January now for another bigger service.
Before I submit to a service at the dealer (for that ten year warranty thing while I can) I thought I'd take the opportunity to service this covering every single service item upfront so that going forward, it's just oil changes and the seldom changed other item as per the schedule. First 3 years - Lexus serviced on the record. Last 3... by a Toyota dealer which according to Lexus doesn't count as a dealer service for the car. It's unclear what they actually did versus what they managed to log on the system, and as they'd lied to my over the Avensis brake fluid change why take the risk?
Everything changed: oil, filter, spark plugs, coolant (for engine and inverter), transmission fluid, wipers, fuel system cleaner added to a full tank of petrol, stone chip repair kit, brake fluid change and engine air filter / cabin filter.
Not without difficulty: the oil filter has a special tool required, took about 45 minutes trying to get that off without the tool (ordered one since). Spark plugs down a very long channel and took a while to carefully get out and in. Liquid pump for the transmission fluid, very difficult due to cheap little pump with a bend in the tube on both ends, sucking air half the time... then the drain plug gushed out with pressure, directly into a bar... which spread the flow wide all over the tools and garage floor, managing to completely miss the pan.. Other than that things went smoothly. Got there in the end.
All genuine parts / fluids as well (well, as you can see, largely Toyota branded but that's how they come).
Booked in for a 'hybrid battery health check' at Lexus next week too... to be safe. That's about the only thing I can't do myself.
Now it's just oil and filter changes which I plan to do every 5,000 using the Toyota/Lexus oil.
I think this was wise to do upfront versus splitting it into a bunch of jobs across the year. The parts are surprisingly all very reasonably priced, easy to find and mostly standard procedure to fit. These things can allegedly do 300,000 miles plus if looked after - imagine that.
