Hi there guys
Note been here for a while, but back in the Uno fold!
So, here is what i brought, a Uno 60 with a Punto GT engine conversion.
I wasn't really looking for an Uno again, however this was absoultey mint! Never seen a welder, been waxoled religiously, was just too good to pass up...
Anyway, here are a few of pics of from the previous owner.
Pre conversion
17436277_10155175486061133_4067005824794538346_o
17505291_10155175486056133_4403625514477524486_o
and a pic of the engine and conversion, nice low mile 33k engine and box from a crashed GT.
33k miles
Few pics showing how clean the chassis leg's were!
17545151_10155202021251133_9017383826645831261_o
17546709_10155202021271133_6284075121915445096_o
And a few of the conversion parts
Turbo Loom
17620464_10155201643396133_4410026011063445848_o
Turbo rack and brake servo
18700503_10155380928311133_6638692855718458288_o
17855263_10155236761556133_5650748184055805630_o
GT Brakes and Turbo Hubs
20915246_10155697191151133_5836332418976815106_n
21231073_10155750781666133_5455011764000393731_n
29790695_10156399968121133_5956662486089564548_n
New valve guides and stem seals
35345776_10156602637951133_1324371981973323776_n
And a few of the pics of how i brought it..
IMG_4290
IMG_4288
IMG_4289
IMG_4291
When i brought it, it had a few issues i wanted to sort, firstly a really unstable idle, and a few bits that i wanted to re-do to my spec. Firstly the fuel system...
This was how it come
IMG_4374
IMG_4350
Firstly, i got a Metal Mk2 Uno Turbo fuel rail rather than the plastic GT one.
IMG_4380
IMG_4372
So, cut off the fittings and TIG welded some AN6 Fittings on
IMG_4381
IMG_4445
I also changed out all the lines to 8mm nylon front to back
IMG_4457
Next i needed to make up a mount for the FPR
IMG_4450
IMG_4452
Next up made up the lines and fitted
IMG_4462
IMG_4862
IMG_4864
IMG_4778
At the fuel tank end i replaced the original turbo tank with a baffled tank. The days of an undertank fuel pump are gone what with the invent of high flowing in-tank pumps
Old tank
IMG_4569
Old vs new pump
IMG_4570
And fitted
IMG_4587
Next up was sorting a pet hate of mine, bad wiring...
Stuff like this
IMG_4373
IMG_4377
IMG_4376
A few before and afters:
IMG_4389
IMG_4388
and after
IMG_4392
Drivers side
Before
IMG_4446
After
IMG_4447
Next up was the engine loom, i wanted to clean up the engine bay, move the ECU and relays into the car and make it look clearner
Here was the loom before
IMG_4395
IMG_4396
Making a template of the original loom
IMG_4478
Mid making
All new wires
IMG_4482 (Medium)
And done, lovely MIL spec connectors
IMG_4624
IMG_4625
IMG_4626
ECU, Relays, Fuses, and Bar sensor moved into the car.
This was the location when i brought the car.
21231651_10155750779106133_4228195100090642726_n
And after, tucked under the dash.
IMG_4610
IMG_4611
IMG_4612
Sorted a few other bits such as this massive leak..
IMG_4384
And cut and welded smooth
IMG_4387
Also fitted central locking
IMG_4645
IMG_4650
IMG_4646
Next up was sorting the lack of any kind of ducting on the intercooler and oil cooler, seen the difference a well ducted design could make on my Supra so figured i would fabricate some up.
Before, you can see the gaps all around where the air would escape
IMG_4659
IMG_4660
TIG'd up some ducts from aluminium
IMG_4667
IMG_4669
IMG_4668
Oil cooler
IMG_4688
IMG_4685
New ducts and stainless hardware
IMG_4689
IMG_4691
IMG_4690
IMG_4693
Much better, now the cooler will do something!
IMG_4779
Next up i wanted to make an AFM mount as it was just floating about, so...
IMG_4707
Picks up on original mounts
IMG_4709
Also made up a cable mount
IMG_4714
Also TIG'd up some new boost pipes to replace the original mishmash, also changed the filter to a stock air filter housing
Before
IMG_4288
Making the new pipes up
IMG_4698
ICV Spout
IMG_4700
Swage the ends
IMG_4703
IMG_4701
Fitted and done
IMG_4705
IMG_4706
IMG_4771
IMG_4775
IMG_4778
IMG_4777
Last job was fitting a light grill i got from italy along with Mk2 Sideskirts
IMG_4718
Next a nice simple thing, getting rid of my old knob as it was a bit blue for me..
IMG_5249
Nice little carbon number to replace it
IMG_5251
Next up was to put a proper Turbo boot on, this is the one that come with the car, looked great but prefered the turbo look
IMG_5385
Weight of the stock metal boot
IMG_5387
Weight of the new fibreglass turbo boot
IMG_5388
And fitted
IMG_5389
IMG_5403
Much better!
Next up was fitting my new boost controller, using the original clock location
IMG_5404
IMG_5407
IMG_5410
Perfect fit!
I still wanted the original digital dash boost gauge to work, so i used the original MAP from the Uno Turbo ECu with a 5V step down power source mounted to the back of the clocks
IMG_5455
Cut down
IMG_5456
And fitted
IMG_5482
IMG_5483
Next thing to replace was the original black carpet with a red turbo item
IMG_5437
Stripped out and cleaned the floor and protected
IMG_5438
IMG_5440
IMG_5441
IMG_5443
IMG_5445
IMG_5446
Above you can see the original sills, the previous owner regularly waxoyld it and you can tell... no rust!
Now thats a carpet!
777B7CDF-CDB2-4ADE-AE3A-96D24E52882F
While fitting the carpet i decided to add the turbo door and rear cards along with electric windows.
This is how the cards were before...
IMG_5562
First up was putting relays in each door, made up a little aluminium mount
IMG_5586
All fitted and wired up
IMG_5559
Turbo door cards, electric motors and rear cards fitted
IMG_5594
IMG_5597
IMG_5596
IMG_5598
IMG_5599
And also fit my new clutch slave as the old one started leaking.. new braided stainless line too...
IMG_5535
IMG_5538
IMG_5471
First the Speedo stopped working! Looks like the original Sharp optical sensor had started to break down
IMG_5613
So replaced with a modern sensor, was very tricky!
Next up was a wheel change, got some Strada 14" Speedlines
IMG_5876
IMG_5875
This is how they come back
CF8F002E-745E-4518-938B-E3B708DCDA21
IMG_6094
Next up was to change the rad, i want a 50/50 split with the intercooler. I looked at a few options but in the end went with a 4 core 60mm thick Civic radiator.
So, here goes...
Stock rad
IMG_5946
As the radiator was rotated 90 degrees i needed to split the radiator flow path, so gap cut
IMG_5975
Plate slid into the gap
IMG_5976
Welded up
IMG_5980
Temp switch bung welded in
DF934471-16FE-4D3E-80BD-D6D6CB60A458
Mount added to top to connect to slam pannel
BCEBC23B-880A-44EB-B9C1-AAC557611DE2
Bottom rad hose fits perfect
IMG_5991
Top rad hose needs some work
IMG_5992
Made a custom top alloy rad hose and added an outlet to the top of the rad
IMG_6123
As the rad was moved right to the passenger side i needed some very small trimming and wanted to push all the air through the rad
Trimmed up
IMG_5993
TIG welded in place
IMG_5998
ground back
IMG_5997
Primered
IMG_6002
and painted
IMG_6018
Radiator wiring done, all contained so a direct plug in connection
IMG_6116
And all completed!
IMG_6136
IMG_6133
IMG_6132
IMG_6131
Here you can see the area left for the intercooler
IMG_6139
Last mod was a little anti social...
Welded a T into the downpipe
IMG_6049
Welded in
IMG_6058
and fitted
IMG_6061
And done
thumbnail_image2
thumbnail_image1
First up was changing the rear bumper to a nice Mk2 one..
Then i had to take a look at the brakes, they were pulling to one side and really needed a stomp to get them to work...
Soon found out why! Pad's were welded in place with rust!
IMG_6359
IMG_6363
Stripped the brakes off cleaner re-painted and new pads
IMG_6358
Much better
IMG_6403
Then i fabricated a new clutch pot as the old ones look nasty
Old
IMG_6341
New with AN4 Lines
IMG_6353
IMG_6354
Next up i wanted to improve the OE airbox as the pipe sizes are tiny and i will eventually be doubling the power
So fabricated this alloy case and s2000 paper filter with ducted inlet from behind the light. This way i get lots of cool fresh air and it allows the engine to breath
IMG_6453
Here you can see the large 3" inlet pipe to the sealed airbox, little perspex window is to make sure nothing gets trapped in the box, 4 bolts allow quick removal and changing of the filter. This
all fits in the stock battery tray so no mods to the shell needed.
IMG_7195
So with the new airbox in place i now had to find somewhere to fit a battrey. Didn't want it miles away in the boot and no way was i mounting it inside the car. A few years ago a cell went down in
an old car i had and started pumping acid into the cabin of the car... not a great experience...
So here is where the batt was, where the air filter now lives..
IMG_7078
Then i thought, there is some space below the battery tray!
So...
Here is the replacment
IMG_7073
IMG_7072
New mount i made
IMG_6857
IMG_6859
New location
IMG_6861
IMG_6862
painted and foam to protect the batt
IMG_7070
IMG_7071
In place
IMG_7075
And new leads fitted!
The leads are all stock Jaguar parts for the battery and required no mods, i also get the benifit of a fuse which the Uno never had. The only change was crimping new terminals onto the Uno starter
leads
Looks OE too
IMG_7071
IMG_7077
So next up i wanted to make a bonnet lifter rather than using the stay all the time
Simple plate that slides into the reinforced section of bonnet to spread the load
IMG_7008
Then a mount bolts onto that
IMG_7010
Here you can see the parts
IMG_7003
The long part bolts in the original airbox mount holes so no holes need to be drilled
The ram is from a Mk4 Golf Bonnet
IMG_7012
Another small mod was finishing the rad setup, i had made a temp top hose out of alloy
IMG_7080
Howver my new AN20 fittings arrived so i welded threaded bungs onto the rad and thermostat and made the new hose
Big!
IMG_6584
IMG_7125
IMG_7127
With the theme of AN fittings i also wanted to make a catch can
So made this tank, here is the inside showing the deflection plates and twin filters
IMG_6778
Fitting welded to the original breather
IMG_6781
Bolts where to the OE air box went so no holes (theme starting here lol)
You can see the drain at the base
IMG_7011
Made the lines
IMG_7189
IMG_7191
IMG_7190
Next on the list is the header tank, hate the big plastic OE one shown here
IMG_6453
So been trying to learn some CAD, made these 2 files over a few evenings
IMG_6570
IMG_6612
Sent them off to a chap with a 5Axis CNC Machine
And these come back
IMG_6822
Fabricated a tank and welded it all up with AN fittings
IMG_6845
IMG_6846
IMG_7079
Last item which is still a work in process is the inlet manifold
Currently my car has the stock Mk2/PGT type
Here is an old pic:
IMG_6131
So, i wanted the better looking Mk1 Manifold but they have a really old odd fuel injector setup, also no spot for a ICV and just need modernising in gerneral
So a stock old Mk1 Manifold
IMG_6366
Here you can see the old style angled injector mounts
IMG_6367
First job was to smooth them out and remove the old mounts
IMG_6406
Both sides done
IMG_6407
Next i tackled the throttle itself. It has no location for a Punto GT TPS and with my future power goals i decided to go for a 57mm (i think) Coupe 20V Turbo throttle body
So, cut off the original
Here you can see the coupe size vs stock!
IMG_6409
IMG_6466
Needs a bit more taking off the stock manifold
IMG_6467
Machined some more out
IMG_6469
IMG_6471
Then welded the new coupe TB flange and also new injector bungs for modern style injectors
IMG_7103
IMG_7113
Started mocking up the rail also, needed some more work to get it bang level but needed to get the holes in place first
IMG_7128
Next up was the throttle cable, needed a new mount for it and i also wanted to suppot the inlet manifold like stock
Made this mount
IMG_7187
Goes here
IMG_7192
and has a step for supporting the manifold
IMG_7193
Test fit
IMG_7179
Quite a bit still to do on the manifold but nearly there... The reason the TPS is facing up is due to the ICV height. Normally the ICV would be straight up but there is no space under the bonnet
hence the TB rotation.
Right next up was adding the PGT Heatshield to the Mk1 manifold
IMG_7209
IMG_7210
IMG_7213
That should help
IMG_7214
Next drilled and tapped the servo fititng to take an AN fitting
IMG_7243
IMG_7244
And test fitted the fuel rail mounts i had designed, these pick up on the original inlet manifold
IMG_7352
IMG_7398
Also designed a new rocker cover
IMG_7399
All that was left was to paint everything up and refit!
IMG_7460
IMG_7464
IMG_7465
IMG_7466
IMG_7467
652486C4-C40C-4300-8FEC-9021A35FD379
IMG_7470
IMG_7471
All was going well!
Then...
IMG_7580
IMG_7591
Seems when the previous owner changed the headgasket the front row of bolts were either left loose or backed off! The bolts were spinning when i removed them!
New Payne Gasket and Bolts
IMG_7660
Also took the checked the cam while it was all apart, and it seems one of the lobes were worn
IMG_7633
So i purchased a new Kent Fast Road Cam!
117715408_1184049468637512_2615549677328085204_n
117644035_618733512107272_4780055688313382112_n
Clearances
117818616_343312560169637_4734051037393991324_n
Meausring old shims
IMG_7654
Working out shim sizes
117843743_349823576419308_4090216532369945941_n
New cam in and covered in assembly lube
117744902_921643884998886_8818175929095699843_n
Engine was really clean!
IMG_7659
All back togther
IMG_7466
Back to daily duties!
IMG_7692
IMG_7691
Pre conversion
33k miles
Turbo Loom
IMG_4290
IMG_4288
IMG_4289
IMG_4291
IMG_4374
IMG_4350
IMG_4380
IMG_4372
IMG_4381
IMG_4445
IMG_4457
IMG_4450
IMG_4452
IMG_4462
IMG_4862
IMG_4864
IMG_4778
Old tank
IMG_4569
Old vs new pump
IMG_4570
And fitted
IMG_4587
Stuff like this
IMG_4373
IMG_4377
IMG_4376
IMG_4389
IMG_4388
and after
IMG_4392
Drivers side
Before
IMG_4446
After
IMG_4447
IMG_4395
IMG_4396
IMG_4478
Mid making
All new wires
IMG_4482 (Medium)
IMG_4624
IMG_4625
IMG_4626
IMG_4610
IMG_4611
IMG_4612
IMG_4384
IMG_4387
IMG_4645
IMG_4650
IMG_4646
IMG_4659
IMG_4660
IMG_4667
IMG_4669
IMG_4668
Oil cooler
IMG_4688
IMG_4685
IMG_4689
IMG_4691
IMG_4690
IMG_4693
IMG_4779
IMG_4707
IMG_4709
IMG_4714
Before
IMG_4288
IMG_4698
ICV Spout
IMG_4700
Swage the ends
IMG_4703
IMG_4701
Fitted and done
IMG_4705
IMG_4706
IMG_4771
IMG_4775
IMG_4778
IMG_4777
IMG_4718
IMG_5249
IMG_5251
IMG_5385
IMG_5387
IMG_5388
And fitted
IMG_5389
IMG_5403
Much better!
IMG_5404
IMG_5407
IMG_5410
Perfect fit!
IMG_5455
Cut down
IMG_5456
And fitted
IMG_5482
IMG_5483
IMG_5437
IMG_5438
IMG_5440
IMG_5441
IMG_5443
IMG_5445
IMG_5446
Now thats a carpet!
IMG_5562
IMG_5586
IMG_5559
IMG_5594
IMG_5597
IMG_5596
IMG_5598
IMG_5599
IMG_5535
IMG_5538
IMG_5471
IMG_5613
IMG_5876
IMG_5875
IMG_6094
So, here goes...
Stock rad
IMG_5946
IMG_5975
IMG_5976
Welded up
IMG_5980
IMG_5991
IMG_5992
IMG_6123
Trimmed up
IMG_5993
TIG welded in place
IMG_5998
ground back
IMG_5997
Primered
IMG_6002
and painted
IMG_6018
IMG_6116
And all completed!
IMG_6136
IMG_6133
IMG_6132
IMG_6131
IMG_6139
IMG_6049
Welded in
IMG_6058
and fitted
IMG_6061
And done
thumbnail_image2
thumbnail_image1
IMG_6359
IMG_6363
IMG_6358
Much better
IMG_6403
Old
IMG_6341
New with AN4 Lines
IMG_6353
IMG_6354
IMG_6453
IMG_7195
IMG_7078
So...
IMG_7073
IMG_7072
New mount i made
IMG_6857
IMG_6859
New location
IMG_6861
IMG_6862
IMG_7070
IMG_7071
In place
IMG_7075
leads
Looks OE too
IMG_7071
IMG_7077
IMG_7008
IMG_7010
IMG_7003
IMG_7012
IMG_7080
Big!
IMG_6584
IMG_7125
IMG_7127
IMG_6778
IMG_6781
IMG_7011
Made the lines
IMG_7189
IMG_7191
IMG_7190
IMG_6453
IMG_6570
IMG_6612
And these come back
IMG_6822
IMG_6845
IMG_6846
IMG_7079
Here is an old pic:
IMG_6131
IMG_6366
IMG_6367
IMG_6406
Both sides done
IMG_6407
IMG_6409
IMG_6466
IMG_6467
IMG_6469
IMG_6471
IMG_7103
IMG_7113
IMG_7128
Made this mount
IMG_7187
Goes here
IMG_7192
IMG_7193
Test fit
IMG_7179
IMG_7209
IMG_7210
IMG_7213
That should help
IMG_7214
IMG_7243
IMG_7244
IMG_7352
IMG_7398
IMG_7399
IMG_7460
IMG_7464
IMG_7465
IMG_7466
IMG_7467
IMG_7470
IMG_7471
All was going well!
Then...
IMG_7580
IMG_7591
IMG_7660
IMG_7633
Clearances
Meausring old shims
IMG_7654
IMG_7659
All back togther
IMG_7466
IMG_7692
IMG_7691
